F32 Bilge smell
F32 Bilge smell
I think I have seen a familiar post in the past, but here it goes.
My bilge in the center of boat that runs from the galley forward smells terrible. What can it be??
- jon_e_quest
- Sporadic User
Many Trojans have a so-called hollow keel which holds water. One way to illiminate the smell is to vacuum it out of that hollow area. This can be accomplished by drilling a 1.25" hole into the cavity up near the v-berth where the bilge is at it's lowest point. This will allow you to vacuum out the water using a small wet/dry vacuum. You can get away with a smaller hole by using an adapter available from Shop-Vac (and sold at Lowe's). The fiberglass there is only 1/16" or so thick. Drill just deep enough using an appropriate hole saw over the longitudinal centerline of the boat. You can follow by pouring bleach into the bilge, then diluting with water to take care of the smell. And obviously, this all needs to be done at above freezing temperatures!
I vacuum out as much bilge water as I can at the end of every season. And you wouldn't neccessarily need to use bleach in subsequent seasons.
Current Boats:
1972 35' Chris Craft Commander
1962 18' Chris Craft Cavalier
Former Trojans:
1972 F-36 Tri-Cabin
1976 F-26 Express HT
1978 F-25 Express HT
Former Trojans:
1972 F-36 Tri-Cabin
- jon_e_quest
- Sporadic User
This topic has been brought up several times before and I'm just one of the lucky ones that haven't had to deal with ongoing bilge stink. I scrubbed my bilge out by hand from bow to stern three years ago and haven't had a problem since. However, that was one of the nastiest and snottiest jobs I think I've ever done.
1975 F-32 "SIMPLY BLESSED"
On the F26 I think the hollow keel runs from the v-berth bulkhead back to under the cabin steps, but the deepest part is just behind the v-berth steps. Like others, I drilled a hole over that area and used a manual pump and even a shopvac to suck the water out occasionally. Then I got lazy and widened the hole with a keyhole saw and installed a bilge hose with filter on the inlet down there, ran the bilge hose back to original manual bilge pump in the hanging locker, replaced the manual pump with a 12v model, hooked into the fuse panel and operated off a push-pull switch mounted just under the regular bilge pump switch on the instrument panel. This gives it a "stock" look. The pump came equipped with a seperate filter housing which I made the mistake of mounting beween the inlet and the pump. Every once in a while smaller particles of gunge make their way past my first "filter" (a screen hose insert used with garden hoses) and plug up the main filter element (a much finer screen). That means I have to remove the cabin floor section and clean that element. I'm remounting the cabin floor next spring and will install a better access to that area. But, the system works great and I don't have to get up close and personal with my bilge.
Randy P
1977 F-26 HT
"Blue Heron"
1977 F-26 HT
"Blue Heron"
- ready123
Correctprowlersfish wrote:I believe the hollow keel ends about where the rear bulkhead ( back of engine room) is not at the transom ,
they do , the hollow keel is below that . When you lift up the hatches and see the bottom of the boat you are really look at the top of the hollow keel ( only in the center)Nancy wrote:Don't you guys have removable hatches running from the bottom of the steps to the V-berth riser?
Nancy
What is the purpose of a hollow keel?? Bouyancy ??
Ron
Ron
Ronald Reagan
1987 F36 Tri-Cabin
Twin 270 Crusaders
"Special K"
Upper Bay, Chesapeake Bay
Ronald Reagan
1987 F36 Tri-Cabin
Twin 270 Crusaders
"Special K"
- jon_e_quest
- Sporadic User
Don't think of it as serving any particular purpose, but merely as a consequence of stiffening the junction between the bottom and the keel.rbcool wrote:What is the purpose of a hollow keel?? Bouyancy ??
Ron
Interestingly, my '72 F-36 does not have a closed-off 'hollow keel'. The keel was left open. Trojan apparantly decided later to strengthen this area by adding the extra glass.
Current Boats:
Former Trojans:
1972 F-36 Tri-Cabin
Former Trojans:
1972 F-36 Tri-Cabin
