I need a set of heads for a 1984 F32 Chrysler 360's "crusaider"
old set to far gone. any help...
sorry if this is not in the right section.
Needed F32 Heads
Needed F32 Heads
"She's Wide in the rear"
Re: Needed F32 Heads
If its a Chrysler its not a Crusader . You could get a set of 360 dodge truck heads from a bone yard and use them . ( install brass freeze plugs) .fastestonehere wrote:I need a set of heads for a 1984 F32 Chrysler 360's "crusaider"
Check with bob or maybe try here
http://bpi.ebasicpower.com/pc/CYLCHR-183/ALL2A
http://www.dougrussell.com/Products/ind ... &Brand=102
- Stripermann2
Any small block Chrysler head will fit.
273, 318, 340, 360.
As Paul says, Be sure to use brass expansion plugs.
273, 318, 340, 360.
