Springtime Projects- be careful!
Saw this on another board and some of you may have seen this. But what came to mind, was that in the doldrums of winter and the anxiousness of getting on our boats this spring...to be careful and double check everything we might have missed or problems which may have occured during the winter lay-up, and to be cautious when commissioning our boats.
Tow BoatUS did a great job saving other boats and the marina from further damage.
I have no idea what started this boat to burn but it's an eye opener.
http://www.youtube.com/watch?v=aRGy41MBhyg
wowzer52
Post by wowzer52 »
A three boats burned in the Kalama marina here on the Columbia river a few weeks ago.A guy was working on his boat at the time it caught fire.....Very depressing.
1975 F-32 "SIMPLY BLESSED"
risctaker
Post by risctaker »
Also and unfortunately, there are many people who have lost jobs, etc in this economy and who have been trying unsuccessfully to get out from under the boat.It's too expensive to keep but too valuable to abandon to the yard so.... That's when "Economic Lightning" strikes !
aka "Basket Case"
383 Chryslers 280 HP V-Drives
Lincoln Harbor Yacht club
Weehawken, NJ
Sorry to see that ,
Heefus
Post by Heefus »
I was very lucky to get a well maintained boat. I am uber paranoid about fumes and fluids. I only found one questionable wire, and it is getting replaced in its entirety.
'76 F28
k9th
Post by k9th »
Very sobering footage and some good thinking by people nearby to move that boat back away from the others.
Tim
"SeaDog"
1979 36' Tri-Cabin
Struts and Rudders
Post by Struts and Rudders »
Have some info...
Based on info I have "heard" through the industry.....
I have no first hand knowledge and as a result please consider this hearsay.
Fire started on Island Boatworks Custom that was to start a re fit early next week."Lisa K" from Providence RI
Fire spread to Viking slip mate "Je Sa Ka" from Road Harbor BVI...she burned to the waterline
Fire then spread to Bertram 57', not sure of the name. She was pulled from her slip to safety...I am sure the owner would have let her go as the damage looks marginal to value.
Lisa K broke free from her slip and drifted across the marina and started a fire on Jarret Bay "Micabe" based in Charleston SC
Somebody has some splaining to do.....
Glad no one was injuired.
SRD
Heefus
Post by Heefus »
'76 F28
Heefus, I couldn't get either link to work...
Here we go with more pics.
http://www.tcpalm.com/photos/galleries/ ... boat-fire/
Muskokan345
Post by Muskokan345 »
Terrible thing. Am I correct in assuming that that was a woodie? I have seen a glass boat burn, and they usually go very quickly right to the water line. She seemed to hold together a long time. Just wondering
1986 F26
Muskokan345 wrote:Terrible thing. Am I correct in assuming that that was a woodie? I have seen a glass boat burn, and they usually go very quickly right to the water line. She seemed to hold together a long time. Just wondering
All fiberglass.
Reel Nauti
Post by Reel Nauti »
Very Unfortunate!
I went down to the boat on the hard for the first time this spring yesterday and was about to plug my charger in when I had thoughts of my engine room bursting into flames and decided to open the hatches for a breather first.
1989 10 Meter International
Twin 454 Crusaders
"Reel Nauti"
Struts and Rudders
All fiberglass.
All wrong...Island Boatworks builder of the Lisa K built in wood with glass over.
For sure the Viking and Bertram were foam and glass.
SRD
Well, from the USCG Documentation, it is listed as Fiberglass. No harm... :wink:
Vessel Name: LISA K USCG Doc. No.: 1119907
Vessel Service: RECREATIONAL IMO Number: *
Trade Indicator: Recreational Call Sign: *
Hull Material: FRP (FIBERGLASS) Hull Number: IBR00018F001
Ship Builder: ISLAND BOAT WORKS INC Year Built: 2001
Length (ft.): 62
Hailing Port: WICKFORD RI Hull Depth (ft.): 10.7
Owner: C & E MARINE LLC
169 BAY ST
PROVIDENCE, RI 02905 Hull Breadth (ft.): 17.5
Gross Tonnage: 77
Net Tonnage: 77
Documentation Issuance Date: January 19, 2011 Documentation Expiration Date: February 29, 2012
Previous Vessel Names: No Vessel Name Changes Previous Vessel Owners: C & E MARINE LLC
Struts and Rudders
Jamie,
I measured for, sold and produced the running gear for this boat.
It was a cold molded wooden boat built on a jig on Hatteras Island NC by Joe Smith and his boys. They were my clients for years....I am quite sure that I am correct, though I can read and see the info you supplied.
The core material for this boat is wood, all surfaces except for teak trim were covered in and sandwiched between fiberglass and west epoxy resin.
SRD
F36
Actually made the running gear for the Viking that burned and sunk as well....
