Where to get parts for Onan generator
TurboTim
Post by TurboTim »
Where can I get parts for my Onan generator. I specifically need headgaskets for it. It is the generator for of my 1981 F36 Tri Cabin,
Welcome to the forum , I'm sure someone here will know a good source of parts for you onan , Have you tried Beacon marine ?
ready123
Re: Where to get parts for Onan generator
Post by ready123 »
TurboTim wrote:Where can I get parts for my Onan generator. I specifically need headgaskets for it. It is the generator for of my 1981 F36 Tri Cabin,
Where are you located?
Why not put it in your profile.....
Onan is owned by Cummins now...
http://www.cumminsonan.com/
g36
Post by g36 »
1997 CARVER 405
"the BLACK PEARL"
past fleet
1978 F32 SEDAN CHRYSLER 318's
current fleet
1997 seadoo gts
1997 yamaha wave venture
1985 sunbird 18 ft runabout
1968 coronado sailboat 25 ft
sunfish
14' hobie cat
canoe
8ft portabote
TurboTim
Post by TurboTim »
Well the problem is I know nothing about the generator. Does anyone know the model number or what kind it is?
There should be a number somewhere on it , unless your the original owner you don"t know if its the same gen-set that came in the boat , so getting a number from someone else could lead you to the wrong info.
Don't know about '80s vintage but the older onan engines had a serial number stamped on the block on a protrusion just in front of the lifting eye. Can you post a pic of your unit? It would help.
