cockpit floor paint question
trojanmanXS
Post by trojanmanXS »
wondering here and figured I'd ask , has anyone here had the questionable idea of utilizing the grey "with spinkled in flecks of black and white" garage floor paint to paint the cockpit floor ?
http://www.homedepot.com/h_d1/N-5yc1v/R ... ogId=10053
would like to eventually sip morning coffee and just hose the floor of when needed and be done with it ,
jddens
Post by jddens »
I used this exact product on my garage floor and it holds up very well with the exception that hot tires tend to lift the paint. I don't see why it wouldn't work good on a cockpit floor.....only concern might be adhesion to fiber glass????
1998 Kawasaki ZXi 1100
ready123
Post by ready123 »
jddens wrote:I used this exact product on my garage floor and it holds up very well with the exception that hot tires tend to lift the paint.
A cockpit floor open to the sun might not do so well then???
wowzer52
Post by wowzer52 »
Boats continually flex. Would that have an affect on that product?
1975 F-32 "SIMPLY BLESSED"
Remember Epoxy breaks down under UV (sun ) light . it needs a UV inhibitor , and I don't think this has it . contact Rustoleum and ask .
Boats2012
Post by Boats2012 »
I have epoxy in my garage, like mentioned above, and I'm not a fan. you might contact a painter or Los Angeles contractors that might have a specialty product. I also like to look at the newer boats to see what kind of material they are using. There are always some products that may be new enough that we are missing...
The newer boats are using gel coat just like the old ones in most cases
Why not Interlux Interdeck...? I mean, how much paint would you need?
That would be a good choice
trojanmanXS
I was on luchbreak and found this item from an old topic http://www.nonslipcoating.com/productinfo.htm
think I found what to use, light gray
jddens
Post by jddens »
Looks like a good option.........let us know how it works out.........John
