Big Round Hole in center of Tri-Cabin Helm Station
rcamaine
Post by rcamaine »
Not knowing what this should look like, I have a large round hole in the center of my helm station on my 1980 Tri-Cabin. It was covered up by this cheap looking beverage holder.
It sits between the two control levers - is about 5" in diamter - drilled clean through the fiberglass. It kind of looks like it would be for a compass of sorts, although I already have a compass mounted on top of the helm panel.
Except for a mistaken hole drilled there by some previous owner - any one have any ideas? Needlees to say I want this covered as it will cause all sorts of leaks down into the galley.
I am going to place a nice piece of teak there instead of that cheesy can holder in the spring.
Thanks.
1980 36' Tri-Cabin - "Jeaga" - Maine
alexander38
Post by alexander38 »
Don't know what hole is for. But I'd glass it in then cover it with some teak..
k9th
Post by k9th »
If it is like my '79, there was a speedometer there. I think it is original equipment. You might check with Bob to see if you can get one. The sensor is probably still in place.
Tim
"SeaDog"
1979 36' Tri-Cabin
Its for a compass . thats were Trojan put them on that year .It was a Flush mount.
aaronbocknek
Post by aaronbocknek »
prowlersfish wrote:Its for a compass . thats were Trojan put them on that year .It was a Flush mount.
i agree with paul. it's for the OEM compass. mine is a danforth constellation.
tri cabin aaron
aaronbocknek@gmail.com
gruhs
Post by gruhs »
I wasn't aware that some models originally had a compass in this location. what do you see when you look down through the hole? That is where the hydraulic steering reservor is in our boat and I have to check and/or top off fluid level annually. If there is anything there that requires access, a removable hole cover of somekind would be in order.
Gary
1977 Trojan Tri-cabin
"Seaweed"
Home port East Chicago, In.
aaronbocknek
oops, i keep forgetting that there were several helm configurations. my compass is right on top of my instrument panel. does yours look like this?
http://www.yachtworld.com/core/listing/ ... id=2279931
tri cabin aaron
