Snapshot from Progressive...
Hi All, Just recieved my device to plug into the diagnostic port on my car from Progressive. It is supposed to lower my auto insurance by as much as 50% according to the way I drive. With a new teenage daughter driver, I need all the help I can get. I'll keep you posted on the results.
Optimistically, Mike
- alexander38
no big bro from Flo in my car...and besides they give alot of money to the hope and change guy.....
- alexander38
Bingo...!
- Commissionpoint
You let your daughter drive with that thing plugged in and I'm sure a rate change is exactly what you will get. I am not sure if its the one you are looking for though. God help you if she has a boyfriend that drives the car when you aren't looking!
1978 F-32 "Eclipse"
Merc 305 SBC's
1.52:1 Borg Warners
1983 Correct Craft
Commander 351 Ford (PCM)
1:1 Borg Warner
Merc 305 SBC's
1.52:1 Borg Warners
1983 Correct Craft
1:1 Borg Warner
I know right...she is driving my old car...w/o the snapshot thingy.Commissionpoint wrote:You let your daughter drive with that thing plugged in and I'm sure a rate change is exactly what you will get. I am not sure if its the one you are looking for though. God help you if she has a boyfriend that drives the car when you aren't looking!
One thing about this thing is that they won't raise your rates, just drop them.
- Stripermann2
One thing I liked from progressive , was they came to look at a customer's car which had rear axle damage from an accident. The adjuster came out, inspected the damaged, went back to his car to do paper work, came in the office with a check he printed off, right there on the spot.
No going back to the office, submitting claims to another office, waiting to have a check cut and sent, yada, yada...simple.
