roll and tip painting
trojanmanXS
Post by trojanmanXS »
is it really as easy as it looks here ?
theres quite a shine on his finished product , wouldnt the brush leave marks ?
http://www.youtube.com/watch?v=k-SGcSlN ... re=related
LandVF36
Post by LandVF36 »
yes, its that easy. First, the roller is hard like a ink roller. If your prep is that flat, it really rolls on that easy. Next, you need to follow the thinning instructions EXACTLY as directed on the product documents for the application temperature. If the paint is too thick, it will look dimply, too thin an you have to do extra coats. Also, when I've done it, I not applied nearly the pressure he was with the brush, its more of a feather touch just to pop all the bubbles left from the roller. After using a brush for 4 x 5 sections, I've tossed the brush and grabbed another one. The cheap natural hair "chip" brushes that cost $0.99 at the hardware store work great. Just make sure the brush them up good and pull out all the loose hairs before you tip.
Current Fleet:
2000 Carver 450 Voyager
1994 Scout 15'
2005 Caribe LCX9 dingy
1981 16' Hobicat
gumper
Post by gumper »
The white you see was painted three years ago. It was done by roll and tip method. No brush marks and better yet no orange pell effect that you get from spraying. There is a very nice Riva beside my boat in storage. It is varnished but done the same way.
You can get a really nice paint job using this method . I may paint my topsides if I keep the boat .I will use the roll and tip method .
jimbo36
Post by jimbo36 »
I have done the roll and tip several times with great results. I tip off with a 4" cheap foam brush and change them out often.
jefflaw35
Post by jefflaw35 »
yea TMAn it flows out, looks great. tipping just kills the roller spots and the paint flows like a river.
Post by Paul »
It's easy once you get the feel for it. This wont' take long. When I did mine, I used a foam brush for tipping and it left no marks. I held the brush at about 30° to the surface and pulled it with only enough pressure to keep it in contact with the surface. It knocked down the bubbles from the roller (West System thin foam roller) and removed the roller marks leaving no brush marks.
IMO the trick was to have one person rolling the paint on and one following directly behind tipping. Don't go over it repeatedly (tipping), one or two strokes will do. The paint will lay down all on its own within a couple of minutes after tipping.
Don't forget, it all starts with proper prep of the hull.
Hope this helps
jefflaw35
Post by jefflaw35 »
Paul wrote:It's easy once you get the feel for it. This wont' take long. When I did mine, I used a foam brush for tipping and it left no marks. I held the brush at about 30° to the surface and pulled it with only enough pressure to keep it in contact with the surface. It knocked down the bubbles from the roller (West System thin foam roller) and removed the roller marks leaving no brush marks.
Hope this helps
This site would be great if it had a "LIKE' button :lol:
Commissionpoint
Post by Commissionpoint »
jefflaw35 wrote: This site would be great if it had a "LIKE' button :lol:
Yeh but that would mean ditching phpbb and getting something like v-bulletin. Site might be worth supporting financially at that point.
Re the comment on orange peel while spraying: That doesn't happen if you know how to spray, have good equipment, and follow the application instructions. Rolling it on and tipping it out with a brush takes a bit of getting used to in order to get satisfactory results, and even at that the results are only so good. I suppose it all depends on if the vessel in question is a keeper or not.
1978 F-32 "Eclipse"
Merc 305 SBC's
1.52:1 Borg Warners
1983 Correct Craft
Commander 351 Ford (PCM)
1:1 Borg Warner
alexander38
Post by alexander38 »
unnecessary shot..
paint job looks great, I'm getting courage from all that I've seen from others that I'll be able to do it with some practice ...
alexander38
unnecessary shot..
Having done a few smaller boats , the methed works well . ( still to chicken to change my hull color )
I do do offer a small tip , do the transom first that way if something goes wrong ( as your learning ) its a smaller area to redo . and if a nat flys in to your tacky paint , let it go and walk away ,other wise you will turn a very small issue in to a big one ,Don't ask how I know :D
Lawman
Post by Lawman »
Are stress cracks (on bow) hard to fix before painting?
1973 F30 Clean Machine
' Goomar '
(Italian for 'my mistress')
jefflaw35
Post by jefflaw35 »
Lawman wrote:Are stress cracks (on bow) hard to fix before painting?
im going on my 20th year of working cars and I only know one true way to fix a stress crack without it coming back. I have tried just digging them out lightly and filling with resin but they come back quickly. My boat is cracked from end to end, I see alot of grinding and reglassing in my future. pretty ugly job. I have one major spot on my haul that I am going to fix today I will show you my procedure pics this evening
prowlersfish wrote:...I do do offer a small tip , do the transom first that way if something goes wrong ( as your learning ) its a smaller area to redo . and if a nat flys in to your tacky paint , let it go and walk away ,other wise you will turn a very small issue in to a big one ,Don't ask how I know :D
You have done this before Paul. Those are two very good points, and those of us that have done this before can deffinitely relate. Can't stress enough the part about walking away.
