Not Trojan but interesting
davidsmith
Post by davidsmith »
I have a friend with a 38 ft Regal with 454 power. Been having trouble with the port engine valves rattling when he ran over 2400 rpm. Anything under 2400 rpm no problems. Oil change was no help. Adjusted valves was no help. Pulled all lifters and inspected them for wear and found no problems. I thought the oil pickup might be stoped up so I pulled the engine and v-drive. Pulled the oil pan and found the oil pickup screen assembly had broken off the pickup tube causing the oil pickup to be about 2 inches higher than normal. When he got on plane the oil would shift to the front of the pan lowering it below the pick up. Welded the screen back on the tube and reinstalled the engine. Will test run tomorrow and report back if anyone is interested.
1977-F36
22`Aquasport
1969 18` Donzi 2+3
akwalker
Post by akwalker »
Good find, I'll bet that was his problem. Good luck with the test ride
1981 F-26 hardtop
"Gracious Lady"
Makes sense David. Yes, please let us know the results. Got my fingers crossed!
Interesting , that should fix it
alexander38
Post by alexander38 »
and I bet it was a press in tube in the first place...why know one tacks those things in drives me nutz along with ring gears....but that was a good find..
davidsmith
Well after much work putting the engine back together got the engine started and adjusted the valves. Ran it for about 45 minutes at the dock and shut it down to check the fluids and found the oil milky. I had to pull the starboard exhaust manifold back a couple inches to remove the valve cover and found water sitting one of the exhaust ports. So we either have a cracked manifold or riser. The saga continues.
1977-F36
22`Aquasport
1969 18` Donzi 2+3
jefflaw35
Post by jefflaw35 »
bummer, I cant wait for my saga to start. Building on a bench that it can be started on but I am sure I will have these issues. Hope you get her right soon...
rossjo
Post by rossjo »
davidsmith wrote:The saga continues.
Ouch.
Just noticed you're on Lake Murray. I have friends who live on the lake. Where are you located? Do you have your F36 on the lake?
davidsmith
Yes Rossjo the F-36 is on Lake Murray at my house right across from the old Lake Murray Marina. They have torn it down and are rebuilding it with apartments. Will still have a restaurant run by Libertys Tap Room from what I hear.
1977-F36
22`Aquasport
1969 18` Donzi 2+3
davidsmith
Finally got back to work on the engine. Removed the intake and found a piece of old gasket material left on the intake. Cleaned intake gasket surfaces and reinstalled. Engine runs perfect now with no lifter rattle and no water in the oil.. 4400 rpm wot. Careless cleaning can ruin your day.
1977-F36
22`Aquasport
1969 18` Donzi 2+3
