Check list: Launch of an F-32 and at the end of the ride
Checklist for boating:
· Life vests for each passenger
· Lifebuoy
· Red Flag
· Fire Extinguisher
· First Aid Kit
· Flashlight and extra batteries
· A functioning horn
· All necessary papers
· Second anchor with line ready
· Fresh water tanks filled enough
· Fuel tank filled enough
· Open hatches first, do sniff test. Then turn blowers on for about 4 minutes
· Shore power off and unplug the cable from shore
· Turn on main electrical switch
· Battery charger works
· Open the engine hatch
· Check engine oil level
· Check bilge for water and make sure bilge pumps run with manual switch ON
· Turn fuel valve
· Start engines and look for leaks in engine room
· Cooling water is flowing
· Close the engine room hatch
· Remove lines and leave the dock
· Check gear oil 1 x per month
[color]
· Keep the blowers running after ride until the engines cooled down
Greetings - Heiner
