Can anyone give me info on my trojan?
The HIN is TRJ3114-0673-460 I had alot of problems getting this boat registered becasue the HIN was not 12 character. Can anyone help me on this?
The strongest reason for the people to retain the right to keep and bear arms is, as a last resort, to protect themselves against tyranny in government.
Re: Can anyone give me info on my trojan?
Assuming its fiberglass:mjeffers2 wrote:The HIN is TRJ3114-0673-460 I had alot of problems getting this boat registered becasue the HIN was not 12 character. Can anyone help me on this?
TRJ = Trojan
311 = ???? (is it actually 321? 311 is NOT listed)
4 = 1974
067 is 67th hull built that year
not sure what the rest is ...
Ref: http://www.trojanboats.net/wforum/viewtopic.php?t=2941
and http://www.trojanboats.net/wforum/viewtopic.php?t=2957
"This Trojan tag has the engine ID number (s), inspector number and the Hull number which is three numbers followed by four. This number is its finger print of your Trojan and is the easiest to work with or decode.
The first three numbers are the model of you Trojan
- 321 is a F 32 Sedan,
- 251 is a F 25,
- 210 is a 25 foot Sea Raider,
- 309 is a 30 foot Sea Raider,
- 301 is an F30,
- 440 is a F 36 TriCabin,
- 460 is a F 36 Sedan,
- 500 is a 42 MY.
The fourth number or first number in the second set is the year. Hull number 321 7045 = F 32 year 1977 second set of three is its production number in this sample 045 is the 45 F 32 built since production started in 1970.
The problem with with the working hull number is that on large production boats like the F 32 some times the production numbering started over. So if you do not know if your Trojan was was build in the 70 or 80 then you would need the TRJ number as well to know if the 7 was 1977 or 1987 "
TROJAN F BOAT MODEL NUMBERS
F 24 SPORT CRUISER MODEL 241, 242
F 25 EXPRESS MODEL 251, 252, 253
F 25 SEA RAIDER 210
F 26 MODEL 261, 262
F28 TWIN SCREW MODEL 280
F28 SINGLE SCREW MODEL 281
F 29 SPORTMAN MODEL 290
F 30 SPORT CRUISER MODEL 300, 301
F 30 EXPRESS MODEL 302, 303
F 30 SPORTS CRUISER SINGLE SCREW MODEL 305, 307
F 30 EXPRESS TWIN SCREW MODEL 304, 306
F 30 FLYBRIDGE SEDAN MODEL 308
F 30 SEA RAIDER MODEL 309, 310
F32 EXPRESS MODEL 320
F32 MODEL 321, 322
F 32 SPORTS SEDAN MODEL 323
F 36 TRI CABIN MODEL 360, 363, 440
F 36 SPORT FISHMAN MODEL 461
F 36 CONVERTIBLE SEDAN MODEL 460
F 40 FLYBRIDGE MOTOR YACHT MODEL 400
F 44 CONVERTIBLE SEDAN MODEL 448
F 44 SPORT FISHERMAN MODEL 445
F 44 MOTOR YACHT MODEL 441, 442, 443, 444,447, 449
F 54 MOTOR YACHT MODEL 541
42 MOTOR YACHT MODEL 500, 501, 502, 503
44 MOTOR YACHT MODEL 441, 442, 443, 444, 447, 453, 454,543
48 MERIAN MODEL 480
53 MOTOR YACHT MODEL 701
53 DECK HOUSE SALON MY MODEL 702
1st - what boat is it (F32, etc.) and what year?
Post a bigger/clearer picture - that is illegible to me.
If you have a wooden Trojan 1945 - 1969 then she would only have a Trojan tag as described above or before 1955 she may only have the three number followed by four stamped inside of the transom, the engine stringers inside of the engine hatch.
If you need help with a TRJ number or Hull number Please call or or E mail Bob@Trojanboats.net
I got it with a title that said F36 1973 But when I tried to get title in my name the NC wildlife people sent me a letter needing a scrub of the HIN so I sent it TRJ3114-0673-460. I have pics of it just cant seem to get them to right size so you can read them
I am in Afganistain right now and am looking for parts that I need to get her up and running when I get home. She was broken into and alot of stuff was broken and stolen. So now I need info to get the parts I will need to get her back on the water when I return to the states. If I am able to
Your metal plate Hull No. 460-3114 decodes as the 114th F36 (460) made in 1973.
The hull rub TRJ3114-0673-460 is ALMOST the same thing in a different order.
Sorry NC is a pain ... I can't help much as my F32 is documented with the 7 digit number like your 460-3114. I have no experience with Trojan state registration.
Bob @ Beacon might know more, as will others here.
By the way - thanks for serving!
- ready123
I agree it is F36 Sedan hull built June '73.
I think 3114 might be the 114th hull in 1973.
When I got her all the registration numbers on the hull and the name was gone. So as far as looking her up to get a boat report it has come up empty. Thank you all for the info I know more already. I need a 12 character HIN and mine is not.
