ATTN: Tricab owners -- spotlight question
There is no spotlight on my 1985 model (but there is about to be). I noticed that there is a switch on the DC panel labelled "spotlight". There is a wire leaving the switch, going down into the mass of all of the other black wires leaving the DC panel. Does anyone know off-hand where said wire terminates? Thanks, Perry
Vitaliy
Post by Vitaliy »
on my 74 model i have that as well except the PO ran a loudspeaker through it instead ofa spotlight, for me it leads straight up and out right in front of the windshield to the actual speaker
had the same question when i saw a similar label and then decided to trace it, hope it helped
1974 F36 Tri-Cabin "Jorallyn"
rbcool
Post by rbcool »
Mine comes out right below the Bow Pulpit..... can probably see it in the rope locker
Ron 8)
Ronald Reagan
1987 F36 Tri-Cabin
Twin 270 Crusaders
"Special K"
Upper Bay, Chesapeake Bay
k9th
Post by k9th »
Mine comes out at the bow and the controls are located right behind the main helm wheel mounted to the vertical wall. It was not original equipment.
Tim
"SeaDog"
1979 36' Tri-Cabin
