Considering Purchase of 1978 F26 Hard Top
Hello Trojan owners. I'm considering the purchase of a 1978 F-26 Hardtop. It's located Ontario Canada used in freshwater lakes.
http://s1061.photobucket.com/albums/t47 ... 48_201.jpg
I'm looking for advice on what to look for and any known issues with this model year. Looks like galvanized fuel tanks, water tank leaks, window leaks and deck core rot may be issues? If there's a thread or website someone can point me to that describes the boat's construction it would be greatly appreciated. Any and all information would be greatly appreciated.
I'm relatively new to boating. I've owned a 1987 24' Sea Ray Sorrento Cuddy cabin for the past 3 years.
Thank you!
Thank you!
- 32pacemaker
F26 leaky windows
welcome to the Trojan web , the f 26 is a great boat, good over all handling, and desent speed with modest power. the problems are fixable with modern marine sealers. the side windows leak around where the frame contacts the fiberglass just remove the frames clean and reseal same with the front windows i through the stock front frames away and cut larger plexiglass windows and sealed them to the fiberglass use about .060 to .080 spacer so the silicone can exspand and contract.
- aaronbocknek
Welcome Bob!
That's a nice looking boat! The F-26 is a really good boat, it's big for its size. As for the boats construction, the hull is solid fiberglass and the decks are fiberglass cored with balsa. I'm assuming the hardtop is cored with balsa as well, mine isn't a hardtop. Most were either powered with a LM318 chrysler 225hp, or a 233hp Mercruiser. It should cruise between 15-17kts and top out at around 25. The deck core is a common thing, and can be repaired. I had to do the same repair that 32 pacemaker did with the side windows, not hard to do at all. As for the front windows, if you search the forum, there was instructions on how to repair the front windows. If you have any specific concerns or questions don't hesitate to ask, I think we've all been there at one time or another. Best of luck,
Matt
Matt
- The Dog House
