78 f32 vent locations
Hi there,I am new to this boat and forum---could someone please tell me where the holding tank vent and the water tank vent exit the boat---Thanks Mike
Welcome to the fourm , Hopefully a F32 owner will see this .
Hi mikeandanne, don't have the answer but wanted to welcome you aboard, and I'm sure someone will be along soon with the info. Is there an issue you want to address, or just exploring?
ready123
Re: 78 f32 vent locations
Post by ready123 »
mikeandanne wrote:Hi there,I am new to this boat and forum---could someone please tell me where the holding tank vent and the water tank vent exit the boat---Thanks Mike
They should be visually obvious...
is holding tank under V berth? If so mine was in port V berth cupboard.
Water tank if in aft maybe under transom cowl in aft.... it overflows inside the boat back deck. Overfill tank to see :)
f32 vents
thanks for the response---the only obvious vents are on the port side--two fuel and one above those two--star. side has only two fuel---the holding tank is metal under the aft deck and has been slightly collapsed so was thinking vent issue---have not got that deck up yet and can not see real good---only had boat for two weeks and trying to think it thru---MIke
kallen
Post by kallen »
On my 81 f-32 both vents are located under the swim platform above the water line midship.
Welcome. Most F32 fuel vents are on the hull sides, just below and slightly aft of the tank fills. My holding tank vent is above water line, forward port bow.
DAVIDLOFLAND
Post by DAVIDLOFLAND »
Stripermann2 wrote:Welcome. My holding tank vent is above water line, forward port bow.
+1
Yanmar 6BY3-260's
