Stuck Window
bjanakos
Stuck Window
Post by bjanakos »
New to me F-32...
I have spent about a total of 4 hours on this boat and most of that cleaning it out and preparing for winter.
When I was there last I tried all the windows in the salon. They all slide open and closed rather easily except the one at the helm. It took quite a bit of force to get it to move.
I had a similar issues with my old boat that ended up being water ingress in the lower sill and swelled the underlying structure. I am hoping this one is not that severe. I intend to clean out the channels on my next visit, but I would like to check in to see if there is a common issue with the window slides. Search results did not turn up much.
DAVIDLOFLAND
Re: Stuck Window
Post by DAVIDLOFLAND »
Both of my forward windows on my 77 F32 are tight, and will not open all the way. Same condition on my friend's 74 F32. I think it may be the top actually 'settling', causing less clearance from top to bottom.
Yanmar 6BY3-260's
bjanakos
Re: Stuck Window
Post by bjanakos »
That's a lot like what was happening with my other boat. Why does it have to be THIS window?
