1978 Trojan F32 Bridge Dash conversion with new Gauges??
Agallinojr
Post by Agallinojr »
Hi, new user, first time Post here. I purchased a beautiful F32 last season, and had a great year with it! This year, i am looking to upgrade my Gauges on the Bridge, i had some inconsistant reads on my Temp and Oil Pressure gauges last year. Looking for any input on what type of gauges to look for, preferably modern style.Any input would be appreciated. Thank You.
Trojan F32.jpg (99.12 KiB) Viewed 11861 times
Trojan Dash.jpg (29.55 KiB) Viewed 11861 times
Re: 1978 Trojan F32 Bridge Dash conversion with new Gauges??
Welcome aboard. Sky's the limit really in terms of which gauges to go with. Just make sure they match the impedance of the senders currently on the engines or they won't work right. Keep in mind that anything between the sender and gauge could also be the reason for poor readings. The wiring, connections, plugs, corrosion, etc. can all be culprits and will still affect readings on new gauges if that's where the fault lies.
Big D wrote:Welcome aboard. Sky's the limit really in terms of which gauges to go with. Just make sure they match the impedance of the senders currently on the engines or they won't work right. Keep in mind that anything between the sender and gauge could also be the reason for poor readings. The wiring, connections, plugs, corrosion, etc. can all be culprits and will still affect readings on new gauges if that's where the fault lies.
this and in Most cases you need senders for dual helms ( dual gauge) ( senders that can run 2 gauges )
gitchisum
Post by gitchisum »
Not sure if they are, but those look like Delco guages, and keep in mind if you replace with modern gauges, you will need to replace the senders also.
I had Delco on my 77 F-26 and learned that lesson when my temp sender went out. Bought the M/C replacement sender and it would not work with the Delco guage. Bob at Beacon helped me through that one.
88 321 Sedan 270 crusaders
2001 Seadoo Challenger 2000
97 Lowe Roughneck 17TC
Welcome to the forum! I'll chime in that if you really want modern, ditch the ol'fashioned analog gauges and go with N2K. I haven't gone whole hog, but when I added a water level sensor to my fresh water tank, it was via N2K to the chartplotter. Same with fuel flow. As a bonus, the GFS-10 that I used for fuel flow includes a digital calibrated fuel level sensor in place of the analog gauge, which is as important as it is notoriously bad.
lawyerdave71
Post by lawyerdave71 »
Boat looks nice!
So what brand gauges should this fellow buy and from where?
This is on my to do list as well.
Captain Dave -
1978 F30 Flybridge Express
IMO VDO analog gauges , of course this means new senders .
Lizz
Post by Lizz »
Pretty! This is on our list, too. Do you have any photos of your interior? I'd love to see.
Proud Owner of a 1976 Hot Mess of a F32 Trojan
Refit started Sept 2015. Finish Date: TBD...
Cmount
Post by Cmount »
When I did this on my f32 I used Faria gauges...no new senders. I used the SS Chesapeake White...I can send a link to a picture if you would like to see it.
1987 Jersey Dawn
"The Other Woman II"
Cmount
Post by Cmount »
I found some old pics of the almost completed project
I trimmed the edges with teak and cleaned the black up with some tire shine stuff
http://s814.photobucket.com/user/CJMOUN ... t=3&page=1
1987 Jersey Dawn
lawyerdave71
Looks nice!
FYI Scotts Liquid Gold does wonders on the Trojan black plastic dashes
Captain Dave -
Agallinojr
So, i haven't checked back on this thread for a while. I ended up getting a full set of Teleflex International Gauges. I installed 1 gauge, (took me about 2 hours). The combination of the lack of spare wiring, and having to change our the Butt connectors, made for a painful project. Debating getting a professional to finish the job. Need to make sure all Gauges are accurate! Thanks for the input!
I switched mine out for the same Teleflex Red Internationals a few years back. And yes, it was a pain to adjust the wiring, but if I remember correctly it was just the ground circuit (that runs daisy-chained from gauge to gauge) that needed adjustment. I just made a diagram of how the wires were routed from gauge to gauge, pulled the old harness, made a new harness with new wire cut to the same lengths but using the right connectors, and reinstalled as per the diagram.
My original gauges were DetMars, so if you have something different maybe more terminals have to be rewired? But for me it was just the one per gauge.
Did you check to see if they match the senders you have ?
