It is I, yet again...Needing clarification on Trojan
daisymai2011
Re: It is I, yet again...Needing clarification on Trojan
Post by daisymai2011 »
Hi thanks for response ...(1989 12 m international convertible) Can you pls let me know how you know for certain it's balsa core ? e.g did you see a cut hull, did you read it in a manual or talk to someone involved in the production process or someone who owns one ? My surveyor seemed to think it was solid fibreglass? Had I not seen the discussion here about balsa core I wouldn't have thought twice about the issue ...
According to Charlie Underwood who was President of Trojan Boats, all Internationals larger than the 10 meter were balsa core
Take a look at his story at
http://trojanboat.com/
Post by El L Sea »
My 1988 12m International Sportfisherman is cored.
daisymai2011
Hi Thks for quick reply (1989 12m international convertible sports fisher)....there is a transducer on bottom that might have been added after production ---just checking into this ... any general thought about this ...Thks
daisymai2011
Hi ....also if all international series above 10 m were cored ... does that mean sides & bottom as well?
Anyone aware of hull failures with Trojans ?
Thks
Ok here is the whole truth on Trojan International boats and coring.
10 meters were not cored
10.8 had about 10 percent cored
11, 12, 13, 14 International Trojans were cored Hull, Sides everything. Anywhere there was something that went through the hull below the water line was not cored. Like through hull fitting, Generator exhaust, struts, AC raw water pick up. The center line of about 1' wide bow to stern was not cored.
Our records show no reported problems with the coring on any 12.13.14 meter boats.
Our records show on two 11 meters there was a problem with the coring. One was caused by a leaking kitchen faucet that sprayed a mist up the bulkhead and the water found its way into the core of the side of the board.
The second one was caused by a bad caulking job at factory on the transom. Water coming over the back of the boat found its way into the coring of the stern.
daisymai2011
Thanks Bob ... I really appreciate the information...do you know if the 1989 12 m sf international would have come with a transducer on the lower part of the starboard hull ? The boat I'm looking at has one but when hit with a .. ---if it was installed after factory it would have been done at least 10 years ago ...
...... regarding the deck & hull joint ---it is covered by a rubber seal & stainless steel rubrail & the sealant has failed on the transom gate for about six inches (did the situation with the 11 m involve anything like this?) ... ....there is also a few soft spots on the deck (one is 2 ft by 2 ft) ...finally just wondering if fishing rod holders in the gunwhale would have been factory or not because there are a few hairline cracks around them ... Thks for any further info you or anyone else are able to provide ...
The transducer was most likely added later. Unless she was order with the X package.
We recomand to potential Trojan buyers to get a owners manual. This way they can use the original invoice as a check list when doing the survey. That way they can see what she came with is still there and working.
As for the transome gate. Just remove / cut away the old sealant and re caulk with 3M 5200 sealant. This is not the same problem that happen with the 11 meter. The 11 meter problem was a factory screw up on one boat.
The rod holders were most likely added latter. The spider cracks are the results of drilling the wholes wrong. Gelcoat is like glass and needs to have a release cut when drilling a whole otherwise it will spider crack. This is only cosmetic and is not a problem.
The soft spot is a problem and must be dealt with ASAP it is like cancer and will spread. You should get a big cut in price of boat for the soft spot or have owner repair before you buy.
daisymai2011
Hi bob ... Thks again for info ... really helpful ...do you have any idea how much deck repair could cost? Or what sort of discount I should ask for ... I've heard varying reports on cost ....I guess for some situations the cost is cheaper & others crazy expensive ...I would be considering what the worst case scenerio cost would be ...thanks for any additional info you are able to provide ...⚓️
Call us
609 713 4602
JuiceClark
Post by JuiceClark »
Dang it YachtSurvey.com! All these years I thought only the 14m was a cored hull because that's what that site says. It certainly seems like it was done right in all models though. I've always avoiding considering a 14m in lieu of a 12 or 13 - which turns out to have been ignorant.
On the F-36 I restored, the entire flybridge was rotten and there were several soft spots on the bow. Fixing the bow spots was one of the easiest projects on that boat. As for the bridge deck, I just cut the entire thing out, built a new one in my garage, set it in place and glassed it in one weekend. Not bad.
However, a wet core in the hull would be quite a hassle for a DIYer. It sounds like there haven't been any real problems though. I suppose there's no condensation when the hull temp stays pretty constant in the water.
Anyway, thanks again for the info. I'm in the market for a new boat this winter.
I have found a lot of miss information on YachtSurvey
JUICE !
YOU ARE BACK !
GET THEE INTO A TROJAN !
NO SEA RAY OR WELLCRAFT WILL DO
NO CENTER CONSOLE OUTBOARD EITHER
THOU NEEDEST AN ICEMAKER ONBOARD
International?
Or maybe Rossjo's F series with diesels ???
Anyway...
Hope to see ya here soon !
We're in for a Ft Myers Resendevous real soon
