Hi All,
Our shore water hook up does not switch to allow water flow, we can only use the on board water tank.
Any thoughts on what the issue could be?
- TDogg
Shore water connection not working
1987 Trojan F36 Tri-Cabin
Re: Shore water connection not working
Check for a clog spiders love those little ports. Or mine has a pressure regulator in line maybe its set to low for your dock side water or it went bad.
Dustin
1999 360 Express twin 7.4
Catawba Island, Ohio
thank you for your post.
where would that pressure regulator be located??
- WayWeGo
Our F-36 Convertible has a pressure regulator added where the water line enters the cabin inside the cabinet at the port stern.
- P-Dogg
As WWG said, right where shore water enters.
