I've been trying to solve an issue with the hatch seals/gaskets on my sort of new to me (my parents bought this boat new when I was 5) 1984 F32. We've always had issues with the foam seals wandering after being replaced. They remain water tight for about a season, then drift and become ineffective.
I finally decided to add aluminum U channel to the hatches to accept the seals and prevent wandering. It's only been a few weeks but I'm very happy with the results. For anyone else interested in doing the same I thought I'd document the process here.
Parts:
24 ft Aluminum Satin Anodized 1-1/6" U-Channel - Amazon
25 ft Water-Resistant Closed Cell Foam Strip, Neoprene-EPDM-SBR, 3/4" Thick, 1" W X 25 ft. L, Black - Grainger
24 Barrel Nuts (8 for each hatch, length less than or equal to hatch thickness, 1/2" in my case) - West Marine
24 pan head screws to match your barrel nuts
24 rubber washers to match your barrel nuts (I cheap-ed out and bought some rubber washers from Home Depot and drilled them out to fit)
Determining the length of cut for the U channel sides took some measuring and If I did this again I'd go about it differently so I won't share the measurements here. If you do attempt this project measure the inside of your hatch opening and use that measurement for the short sides of your mitered u-channel.
One thing I discovered, is that the foam seal contracts longitudinally after removing the paper from the tape. Measure and cut your seals 1 or 1.5 inches longer than needed to avoid gaps.
Now for the reveal!
Joel
1984 F32 "Second Course"
Belle Maer Harbor, Harrison Township, MI
Here's a pic of the dimensions for the u-channel in case that Amazon link doesn't stand the test of time. I also forgot to add that I decided not to seal the mating surfaces between the aluminum and plastic hatch but may do so in the future. I plan on using 3M Fast Cure 4000 UV for its bonding strength to both plastics and metals.
Joel
