Cutting Taff rail
Mordaunt
Cutting Taff rail
Post by Mordaunt »
For those of you who have installed hinges on your taff rail, any advice on type of saw or blade to use? The hardware I bought does cover the ends however I’d love to avoid any splintering etc as much as possible. Cutting into original wood is somewhat intimidating!
1985 Trojan F32
Re: Cutting Taff rail
Any nice hand saw will work fine, if you are concerned about chipping just tape the cut and score with a knife first, but I think you will be just fine.
The fittings I got took quite some modifying to the wood to fit as wood end profile and the hinges did not match, was doable though.
mikeandanne wrote: Wed Mar 27, 2019 8:19 pm just tape the cut and score with a knife first, but I think you will be just fine.
^^^^^this.
