F26 stringer numbers?
My '1972' F26 has 250 540 stenciled on strbrd stringer under the staircase........got me wondering since someone posted model numbers for wood boats are located on the stringer. 250 540.....I haven't seen any reference to those numbers.......
Re: F26 stringer numbers?
Many times they are marked as to what hull they go to , Bob may have more info
Not a Number Trojan used per Bob
Any chance the numbers have "NO. # " in front of them ? could be a USCG Doc number if it was documented at so time . I tried running the number but site is down .
Not a good Doc number and not a good Trojan # Any chance a number is missing or wrong ?
- P-Dogg
That is a part number.
- P-Dogg
Am remodeling my forward head. Port light has a sliding cover, with handle. Just a simple piece of teak cut at an angle. Took the handle off of it so I could countersink the holes a bit more. Here's a pic of the underside. Guessing your numbers look like this?
Also have my aft cabin headliner down. The handwritten number is on the bottom edge of the port bulkhead of my escape hatch, so not all numbers are machine-made.
- 15921597396154581141494591810202.jpg (85.58 KiB) Viewed 3831 times
- 20200614_142208.jpg (61.93 KiB) Viewed 3831 times
