75 F32 Accessories Switch
- AwayOnBusine$$
Anybody have any idea what function this should perform. There have been many different devices on this boat over the years. There a holes everywhere. I have had the boat for 6 years. Have not found a single function this switch controls.
F32 Fly 1975
Re: 75 F32 Accessories Switch
I believe Trojan installed them for any Accessories that maybe added latter . I have 2 myself .
If you look at your wiring diagram , it will show were wiring from each switch goes . I think you may find that switch may dead end .
+1prowlersfish wrote: ↑Mon Jun 22, 2020 11:00 pm I believe Trojan installed them for any Accessories that maybe added latter . I have 2 myself .
It would have started out as an additional 15A circuit for whatever you may want to wire to something, but you would have to trace wires to see if any previous owner has connected it to anything. I have a Raymarine depth sounder that has no power switch (so the LCD is 'always on') so wired that up to the Acc switch to turn things on/off as desired.
- AwayOnBusine$$
