neutral switch
neutral switch
i just replaced my transmission cable on the strbrd 318 engine on my 73 f-31. but it won't start even when i jiggle the shifter control when in neutral. where is this switch located ? dean
neutral switch
got ya thanks dean
Dean,
You can check the switch by simply by by passing it. Just remove the two wire going to the switch and connect then together using a small bolt. If it starts its the switch, if not check the started. PS don't leave the wires connects, its a huge safety issue.
Good luck
Good luck
Todd Pote
1987 10 Meter Mid Cabin
Double Pote-N_Sea
Double Pote-N_Sea
