seal on glass sliding door on salon
dgielow
Post by dgielow »
has anyone replaced or had trouble with the salon sliding door leaking
Re: seal on glass sliding door on salon
Might help if you stated the name, rank, and serial number of your boat.......
No but I nave no clue if yours is like mine or not :?: :shock:
dgielow
Post by dgielow »
i have a 1988 12 meter international sedan bridge
Can you tell if its coming in between the glass and frame or getting around the door it self ?
dgielow
Post by dgielow »
no, i guess i will half to flood the door and watch
dgielow wrote: Sun Oct 11, 2020 3:10 pm no, i guess i will half to flood the door and watch
Just don't hit it with a full blast , as you could make a leak where its not and mislead you .
JG1970
Post by JG1970 »
I have a 1985 11 meter Sedan, I’m finding a wet spot in front on the sliding door. Thought it was the ice maker, shut it off, dried the spot. Rain and blowing found it wet in the same spot. I think it’s coming from the seal under the door frame.
1985 Trojan International 11 Meter Sedan
