chrysler 280 on 36 tri cabin
silly question, but i'm not a mechanical type at all, and am curious...
i'm thinking of buying a 36 tri. the ad says it has twin chrysler 280s, with 280 horsepower.
is that correct? if not, does anyone know what the hp of these engines are? i've looked for a hour on the net, and can't find poo.
thanks!
thanks!
What year ? the 280hp was a 383cid up till 1971 and 400cid 72 on up . good engines IMO . the horsepower was of course 280
- aaronbocknek
I'll bet they they should be more correctly called Mercruiser 280's. Take a look at the name plate on your engines & see what it says for Model # & Serial #. Mercruiser takes various car manufacturer engines, 'marine-izes' them, and calls them by their horsepower rating. I've got a tri-cabin with Mercruiser 255's, which are basically marine-ized GM 5.7L, or 350ci truck engines rated @ 255 HP each.
I was always a fan of the Chrysler 318's & 383's, so, if your engines have been taken care of, you've got some sweet engines there.
- TADTOOMUCH
Engines
My Chrysler 250's are actually 360 cu.in. displacement. Straight interpolation would give you about 380 cu. in. displacement for a 280 hp engine.
Boat Name: A TAD TOO MUCH
Re: chrysler 280 on 36 tri cabin
I have a 1976 Trojan F36 tri deck with twin Chrysler marine 280 and the Model number on the engines are #400BWL10/597. The engines were kept very well however I am into my 1st impeller change which is a Sherwood by the way. I am on Lake Simcoe. Good luck
I have the 400s and had them rebuilt I love them so much!
