Sparkplugs in a 400 cid
Just curious what plugs you are running in the 400 chryslers. The operating manual calls for XJ-10Y (Champion). Most people I talk to recommend 1 level hotter plugs with todays fuel. Any opinions? Jimbo36
I come up with RJ14YC as the champion number for both the 400 and 440 . I have seen champion change the listings over the years . BTW the XJ10Y was replaced by the RJ12YC .
There is a easy look up on this site
http://championsparkplugs.com .
Of course there are other brands of plugs but champon was OEM on crlysler marine and seem to work the best on these .
Pwollsch you seemed conserned on what plugs you used bringing up a old thead what # and brand did you use ? I have a good data base and would be glad to help .
I used Champion RJ12YC. My Chrysler M400's have 1900-2000 hours, and I am trying to treat them delicately. I am satisfied with performance of plugs, just have read where some guys run hotter plugs, and I did not know the science behind it.
1072 14 ft Meijers - Sears outboard
1990 17 ft Sea Nymph - 70 Johnson
1992 17 Tracker Deep-V - 40 Yamaha (still own)
1987 266 Cruisers Inc - 460 King Cobra
1974 F36 Trojan - Twin Crysler M400
A plugs heat spec is is it's ability to dissipate heat from itself to the head. The proper heat range is a delicate balance; too high a heat range and the plug dissipates too much heat not allowing the tip to reach a temp that helps keep it clean, fouled plugs etc. Too low a heat range and it won't dissipate enough heat causing the end to burn up, and produce hot spots that could create a pre-ignition condition. The OEM heat range requirement is based on the engine design. After running for a season, a plug will tell you if you need to change the heat range providing the engine is properly tuned and mechanically sound, ie ignition, fuel delivery, compression, not burning excessive oil etc.
Big D don't you have That backwards ? ( on the heat range )
a Quote
"The insulator material control the heat range. In the hotter heat-range spark plug, a longer insulator nose creates a longer heat flow path from the insulator tip to the threads and a smaller heat transfer area in the insulator, which allows heat to build up in the tip. "
a Quote
