Transporting a Trojan
Hey Gang...
Quick question....if I want to move a Trojan F-32 by truck, must the flybridge come down? for example, from Rhode Island to New jersey.
some people tell me no...and others say yes. Also, who is responsible for removing it, the trucking company or me. Would it be difficult or easy to remove it??? I appreciate all you input!
Thanks Gang.
Thanks Gang.
Re: Boat hauling
When I bought my F-32 it was on a trailer and I was able to use the trailer to bring it home and then return the trailer. It was 15 ft. high on the trailer and that is way over the limit for anybody but I pulled it myself with a one ton duelly and stayed off the main roads. I only had to go 140- miles and I did it at daylight on Sunday. I have been told that if I had been stopped I would have been in serious trouble. I probably would not try it again. I didn't hit anything but was vety nervous. Be careful. The flybridge removal depends on the person. Better if you can lift it off in one piece but it's heavy to do by hand. Good luck, Captain Don
Run the boat yourself......just take it slow and enjoy the view
TIKI III
1985 F32
270 Crusaders
Wet and happy
1985 F32
270 Crusaders
Wet and happy
Re: Transporting a Trojan
nurse1 wrote:Hey Gang...
Yes, it needs to come off.
You. Most marine yards can do this for you, but it won't be cheap..
It's about a day's work with two people. I've done it on mine when it was down in Fl.
I would run the boat down via water way...![]()
Thanks Gang.
flybridge must come off because of power lines, signals and bridges. is also considered a "wide load" at 13' and it would be your responsibility to remove the flybridge or hire a marine mechanic to remove it. i would refrain from allowing a hauling company to do it unless they do this type of work.
4 people can lift and place on the foredeck (bulky) or use the lift at the marina.
i had my f32 moved from boston, ma to western ny and was told by some transporters i would need special permits and escorts but found a guy to haul it for $1600 i believe.
- ready123
I disagree with this blanket statement... it is possible to haul a F32 with bridge in place using a low beam trailer.trepka2001 wrote:flybridge must come off because of power lines, signals and bridges.
Using a low boy trailer allowed me to move mine... all I had to do was remove the windshield and tilt the helm console to below the bridge surround height. We then used a highway route that had bridge heights to suit.
Some boats cannot reduce their height and are still moved by selecting routes that allow for the height...
In my experience large boat hauling companies have the required wide load permits in place to cover the transportation regs.
Try these guys:
http://www.andrewstrucking.com/
If you want to move it by water Contact Wes . He just ran his boat from Ct to Va and back a few weekks ago , I will bet he would glad to go along and help . Great guy but hide you orange slice candy or you will never see it again.
if wes gets the job maybe he needs a co captain i sure would like to volunteer
hey wes!!!
hey wes!!!
1997 CARVER 405
"the BLACK PEARL"
past fleet
1978 F32 SEDAN CHRYSLER 318's
current fleet
1997 seadoo gts
1997 yamaha wave venture
1985 sunbird 18 ft runabout
1968 coronado sailboat 25 ft
sunfish
14' hobie cat
canoe
8ft portabote
"the BLACK PEARL"
past fleet
current fleet
1997 seadoo gts
sunfish
14' hobie cat
canoe
8ft portabote
Count me in too! If the boat is in good enough shape the cost for fuel might be less or equal to the cost of transport and you'd get a good idea of what she's capable of as well as anything that would need to be fixed or improved. We put over 500 miles on the mighty Blue Heron last year and learned just how capable even a 26 was. Now I know that the Erie Canal and Lake Ontario and Lake Oneida are not the ocean, but they can get really really hairy so I'm ready to rock and roll!
Randy P
1977 F-26 HT
"Blue Heron"
1977 F-26 HT
"Blue Heron"
yes, if your only going a short distance but this seems a little far not to run into bridges etc.ready123 wrote:I disagree with this blanket statement... it is possible to haul a F32 with bridge in place using a low beam trailer.trepka2001 wrote:flybridge must come off because of power lines, signals and bridges.
Try these guys:
also when it comes to permits every state has different rules as well as what permits the trucking companies have. why buy state hauling permits for Nebraska if you don't haul there????
