New Hardtop project I'm planning...
Paul - SW Ontario
Post by Paul - SW Ontario »
Design stages obviously...but what do you guys think?
I will built it with strength but keeping it light.
Imageimg][/img]
1973 Trojan F25.5 - SW, ON.
2012 Triple Axle trailer
1978 C&C Mega 30' Sailboat
2014 Triple Axle trailer
2016 Highfield CL290 BL RIB
2017 20hp Suzuki 4 stroke
Paul - SW Ontario
This would be the look with the camper sides...
:D
Image/img]
NICE
MattSC
Post by MattSC »
Looks pretty slick! I like it
chauzer
Post by chauzer »
looks good! how much higher then the windsheild are you going?
life is tough! it's even tougher if your stupid.
~john wayne~
Paul - SW Ontario
not so much that I hit bridges...lol
Thinking about 5" of lexan acrylic above the windshield.
My thoughts are to have them lift open to provide air while cruising, instead of the windshield being open.
Also, because I am 6' 2" standing at the helm, I look over the windshield, so the extra glass there would be convenient.
Rodman
Post by Rodman »
Paul - SW Ontario wrote:not so much that I hit bridges...lol
Be sure to document the build.
Trojan
ready123
Post by ready123 »
What material are you planning on using?
My buddy made a hard top for his F32 using 1/4" Starboard on Aluminium channel supported by stainless tubing from bridge surround.
One thing I like about yours is the rigidity you should get from attaching it to the windshield.
If it looks half as good as you photoshop work it will be sweet.
Paul - SW Ontario
Thanks Michael...
My thought process is to keep it as "marine" or factory appearing as possible.
3/4" square thin wall aluminum tubing for the hard top sub structure...welded.
Including the underside rails that the camper top and upright supports will attach to, and the aluminum support that will rest and fasten to the windshield.
Thin walled so that the tubing even being square can be curved to mimic the cabin top shape. Then between the ribs or cross members tightly fit 3/4" stryro foam so that the entire hard top takes on equal thickness.
The same for the two uprights. The uprights and supports will have the mounting hardware in place before the fiberglass work begins.
Then apply two sheets of fiberglass and resin covering all surfaces top, bottom, sides, edges & lips.
Sand and shape...then 3 or 4 coats of filling primer.
Sand smooth and paint with Interlux Brightsides, to match the topside I am doing April.
Of course there are more details, but that's the basic plan.
Looks great
jimbo36
Post by jimbo36 »
That looks awesome!! Love to see it finished. Is that a retractable clear sunroof?? Jimbo36.
Rodman
Post by Rodman »
Paul what design software are you using
Trojan
Peter
Post by Peter »
sweet, love the computer tricks, too
LSP
Post by LSP »
Looks great ....
Will - LSP
1976 F32 "Donegal"
1985 10 Meter "Whakanui"
Hog Pen Creek
Middle River, Md
foofer b
Post by foofer b »
Will it have a suroof/moonroof panel?
MY CURRENT FLEET
2003 KEY WEST 2020 WA
1978 14' ASHCRAFT SKIFF
