fridge help.....
fridge help.....
I have a 25 trojan ht, the fridge in it has gone bad, I have unhooked all the wires and the 115 plug, removed it from its resting place, went to take it out the door, and guess what????? it wont fit thru the door, any tips or suggestions, short of removing the rear cabin wall.
Re: fridge help.....
That sucks..... Take out one of the front windows.turtlem1969 wrote:I have a 25 trojan ht, the fridge in it has gone bad, I have unhooked all the wires and the 115 plug, removed it from its resting place, went to take it out the door, and guess what????? it wont fit thru the door, any tips or suggestions, short of removing the rear cabin wall.
Trojan
- ready123
How much smaller is the new one?turtlem1969 wrote:I have a 25 trojan ht, the fridge in it has gone bad, I have unhooked all the wires and the 115 plug, removed it from its resting place, went to take it out the door, and guess what????? it wont fit thru the door, any tips or suggestions, short of removing the rear cabin wall.
If you need to get the new one in too.. I guess you have to remove the wall.
If you are not replacing it then why not take it apart... don't cut any tubing but you should be able to cut the case down to get it out.
tried removing fridge door, still about two inches to big no matter how i turn it, the new one is a little smaller and will go in barely (according to the tape measure). I dont think the front widows are any bigger than the door, but will check that. May just have to take the old one apart, with out cutting any lines.
thanks for the suggestions,
What a bugger... A friend of mine had a 3/4 size fridge in a Viking 43 Double Cabin that got fried.... had to pull window treatments and trim, remove a side window, and cut a chunk out of the remaining framing to get it out and thew one in (with 1/4" to spare). Then had to get a guy try to match the stain and finish of the wood window trim to patch things back together. Net result was an 80% job, as you just can't match the colour of weathered and used/abused wood with any stain colour.
See if any windows or hatch are bigger than door opening (but I doubt it)... if not, follow ready123's approach and hack it in to manageable pieces, and make sure the new one fits !!! (That's another issue my friend has just adopted - the new one had to come in the same side window as it doesn't go through the door either! His wife said if they lose that fridge too, they are selling the boat 'cuz she's not gonna hack apart the trim again).
they built the cabin around the fridge?
that doesn't seem possible, not that I doubt your measurements. As mentioned, there's a lot of empty space.
You'll be able to come up with 2 inches (sawz-all) pretty quickly.
- Location: Mt Juliet, TN. Percy Prist Lake, Fate Sanders Marina
Silly question, I know,,,,,but are you sure you got an F25. I have an F25 HT also. I took the door off the old fridge and it was still tight, but got the fridge out the cabin door, and the new one in, the same way. You must have a very large fridge? I'd like to see pic's of your F25, having one myself and I don't see
to many F25's on the forum.
Larry
Larry
Lets see if this works http://s776.photobucket.com/albums/yy45 ... 0F25%20HT/
- Paul - SW Ontario
Already answered your question a few weeks back....cut away the insulation on the back side and remove the door....turtlem1969 wrote:I have a 25 trojan ht, the fridge in it has gone bad, I have unhooked all the wires and the 115 plug, removed it from its resting place, went to take it out the door, and guess what????? it wont fit thru the door, any tips or suggestions, short of removing the rear cabin wall.
1973 Trojan F25.5 - SW, ON.
2012 Triple Axle trailer
1978 C&C Mega 30' Sailboat
2014 Triple Axle trailer
2016 Highfield CL290 BL RIB
2017 20hp Suzuki 4 stroke
Paul - SW Ontario wrote:Already answered your question a few weeks back....cut away the insulation on the back side and remove the door....turtlem1969 wrote:I have a 25 trojan ht, the fridge in it has gone bad, I have unhooked all the wires and the 115 plug, removed it from its resting place, went to take it out the door, and guess what????? it wont fit thru the door, any tips or suggestions, short of removing the rear cabin wall.
some people dont listen
TIKI III
1985 F32
270 Crusaders
Wet and happy
1985 F32
270 Crusaders
Wet and happy
