Oil: How many quarts?
Tuck
Post by Tuck »
i changed the oil in my engines this weekend (and as i'm mechanically retarded...yea me!), and i want to make sure i'm not going nuts or anything...
how many quarts of oil should a chrysler 318 take? i thought they took right at 5 last year, but they each took 6 this go-round. the only thing i did differentlyi was NOT to put oil in the new filters before i put them on. do the filters actually suck up a quart?
oh. also. what weight of oil do you guys use for the 318s? i used castrol 10w 40 last year, and used the same this year. its' what someone suggested last year, so i stuck with it. but as i was finishing saturday, a dock neighbor said i should have used mercruiser oil of a heavier weight?
Terran
1986 Silverton 40' Aftcabin
Terran
(former 1977 F-32)
larglo
Post by larglo »
Tuck,
This is a great question, one which I have been wondering about myself.
According to a Marine Chrysler manual for the 318 engine, I downloaded off the internet, it says
For engine design M318 A,,,,,,M318 B and C, the crankcase capacity is 8 qts @ 7 degs,,,,and an additional qt when filter element is changed. (making it 9 qts)
I am assuming the filter will not be filled prior to installation?
This sounds like a very large crankcase?
I look forward to seeing others on this subject, as I am looking at buying one of those dip stick oil extractors and change mine soon.
Larry
Larry - 1980 F25 HT
"Lady G"
Mt. Juliet, TN
randyp
Post by randyp »
How did you get the old oil out? If through the dipstick with a pump it doesn't always drain the entire crankcase/sump. 6 quarts sounds about right. I use 10W-30 and this has worked fine. The engine is still original, no rebuild, and runs fine. What you are using probably is fine too. Remember these engines are over 30 years old, most designed to run on leaded regular (the 318 that is). So the oil you are using is probably a step ahead from what they were designed to run on, IMO. :roll:
Randy P
1977 F-26 HT
"Blue Heron"
g36
Post by g36 »
first congratulations tuck on changing your oil.
did you suck it out through the dipstick hole?
i usually run straight 30w or 10w30.
6 quarts sounds about right. how much did you pull out of the engines? you could use that as a starting point for the quanity needed for replacement. were you topped off before you started the oil change if so should be the same as removed.
i try to at least put some oil in the filters as i change but since they are inverted i can only get in enough that will soak in the filter so it wont run out when turned over to screw on.
i do warm the engines before i start the oil change rather than trying to remove cold oil works pretty well.
1997 CARVER 405
"the BLACK PEARL"
past fleet
1978 F32 SEDAN CHRYSLER 318's
current fleet
1997 seadoo gts
1997 yamaha wave venture
1985 sunbird 18 ft runabout
1968 coronado sailboat 25 ft
sunfish
14' hobie cat
canoe
8ft portabote
15w40 thats what I have been using for years gas or diesel . a lot of crusader and Marine power also recommend it
I have 360s, and I typically change about 6 quarts when I do mine.
As for oil weight - I use a straight grade SAE40. I had heard a while back that some multi-grade oils may break down in marine engines due to how much harder things are worked. Also, my engines are 30 years old, and I think straight grade is better for them.
15w-40 won't break down ( I would not use 10w-40 ), straight 40w kind of thick for cold starts up north , I would think . 10w30 would be ok in cold climates
k9th
Post by k9th »
I use 15w-40 also here on the Great Lakes. Since our boating season is basically during warm weather, that grade seems to be best for all around usage.
Tim
"SeaDog"
1979 36' Tri-Cabin
larglo
Post by larglo »
Tuck,
How did you get the oil out? Through the dipstick? My concern also is getting ALL the oil out, or at least the majority of it. But from what I can tell, I can't see any other way but using the dip stick method.
I think running the engine to warm up the oil is a good idea, so as to ease the flow through that small hole.
Larry
Larry - 1980 F25 HT
"Lady G"
Mt. Juliet, TN
Tuck
Post by Tuck »
i used a pump with a hose thru the dispstick to extract the oil.
before starting, i took the boat out and ran it for a while to get it nice and warm, then headed back to start the oil change.
i'll keep in mind what you guys who don't like 10w40 are saying. but since it's already there, and it's what i used last year, i'll leave it until next year and then change the grade.
tks for the input. :D
Terran
Terran
(former 1977 F-32)
Lawman
Oil
Post by Lawman »
Hey guys! After Changing oil with 5 quarts through dipstick (manual says 6,tube couldn't reach last quart ) and using 15-40,one motor still has a lifter noise, are these things adjustable?? Also thought about using Marvel Mystery oil... Any thoughts???
Post by Paul »
If you're using an electric pump with a plastic tube that you insert thru the dip stick, here's a little trick to get that last quart out.
After you warm the engine (oil) and insert the tube, use a little electrical tape and to wrap around and seal the gap between the dip stick tube and the plastic tube. Now pump out the oil. :D
The reason this works is simple. Since the dip stick tube extends to the bottom of the pan, when the oil starts to get low in the pan air gets drawn down the dip stick tube and short circuits into the pump tube stopping the flow of oil.
Hope this helps.
Lawman
Oil
Post by Lawman »
Thanx Paul. I actually did put a rag around the top and held it tight, I did notice a difference. Just a correction from my last post, my engines hold 5 quarts total (per manual), i only could get 4-4 1/2 quarts out. I have twin 1989 ML 318's
