Need Info On Kubota/Phasor Generator Water Pump-43' Trogan-
In need some info on and 88 or 89 Kubota Generator..i Need The water pump and the # on the side of the pump is is 202M17..Can anyone help me out in this matter?
Here is also the name of the company that can supply you with just about any pump or pump part. Couldn't think of them earlier...give them a call.
http://www.depcopump.com/
Re: Need Info On Kubota/Phasor Generator Water Pump-43' Trogan-
Where did you end up getting the parts? I too have Phasor 7.0kw generator with the Oberdorfer raw water pump N202M-17P. The P on the end I think means is was special for Phasor generators. Two bolt flange mounts it to a Kubota diesel.
All of the online sources stop at N202M-16 or have some data on the N202M-17 but nothing about the N202M-17P.
The online diagrams show under the pump cover an Oring, washer, snap ring, impeller, and then another washer.
I took my pump out today and there is just the cover, Oring and the impeller, that's it.
I tried contacting Phasor, Kubota and depcopumps but I haven't heard back from them. Any one have another source.
I need to replace the cover due to wear, the Oring and the impeller but I can't find a definite source for the parts to this.
Phasor Model K3-7 KW
Serial 05665
Serial 05665
I would Call Depco
http://www.depcopump.com/datasheets/obe ... 7P_BOM.pdf
I found a Bill of Material list for the pump after hunting around on their website.
