F 36 Convertible
- cclark75006
F 36 Convertible
I am currently considering moving up from my F25 to larger F36 (Convertible) and wanted some of the forum members who own this model, or are familar with it to weight in on these qustions:
1. Is the Boat a good blue water vessel or should this model stay on inland waterways only?
2. Max sea and wind condtions you have operated in with comfort/safety?
3. Besides a sea trail and survey, any comments on any year models, engines to avoid or any other comments to assist in a search?
Thanks for the assistance.
1980 F32 Sedan Flybridge
I would not call it a blue water boat But My idea of a blue water boat is a Viking or a Bert. I know of several that have been used a lot off shore. I have been Thu some terrible stuff with mine.
Its a good all around boat
Engines to avoid believe or not the few I list are diesels . Some came with Cummins 504 (V8) great engine but dated and part are getting hard to get and $$$ . crly/Nissan diesels for the same reasons and under powered , Mitsubishi same thing.
Good Diesels ? Cummins B (5.9)seres great match ( avoid 4.2l merc/cummins ) most yanmar and volvos are good .
Gas motors ? I don't think any one is Bad or any brand is light years better , Condition is the most important thing .
As Paul mentioned, a good all around boat. It's beam to length ratio gives it an edge over the 32 for sure...especially in a following sea.
They are tough boats, no doubt.
Dependent on what year you're looking at, I would look at a model with Crusader engines (454). Defintely stay away from the 460 with the Chrysler plumbing. These are fantastic engines, however trying to get cooling system parts, exhaust parts, etc are almost non-existant.
Of course diesels are nice but again, dependant on which model engines. Paul, Rossjo, RWS and Jav are knowledgeable in this department, as they run diesels.
The F36 is a great boat, take your time, look and ask lots of questions!
Good luck in your quest.
Growing up our definition of FORD : Found On Rockville Dump.
There are others but I shouldn't cuss on here
Ronald Reagan
1987 F36 Tri-Cabin
Twin 270 Crusaders
"Special K"
Upper Bay, Chesapeake Bay
Ronald Reagan
1987 F36 Tri-Cabin
Twin 270 Crusaders
"Special K"
Ford is ok.
F***ING OLD REBUILT DODGE
FIX OR REPAIR DAILY
ETC.
FIX OR REPAIR DAILY
ETC.
Ronald Reagan
1987 F36 Tri-Cabin
Twin 270 Crusaders
"Special K"
Ronald Reagan
1987 F36 Tri-Cabin
Twin 270 Crusaders
"Special K"
Can't leave the european cars out...
For every Saab owner, there's a sob story.
Ok, let's get back on the subject.
- cclark75006
- cclark75006
- cclark75006
I may be wrong but I think the 360's are small blocks and I don't know if they would hold up that long pushing a 20,000lb boat. I would try to stay with big blocks. Engines won't have to work as hard.
2011 Trojan Rendevous
Solomons Get Together 2011
Ocean City 2012,2013,2015
