water heater trips breaker
trepka2001
Post by trepka2001 »
everytime I switch on my water heater it trips my circuit breaker, any suggestions on what could be causing this?? bad water heater or worn breaker?? thanks
could be either one or a short in the wiring , is it poping the breaker for the water heater or the main ? If its the main is anything else on at the time ?
If it is the heater then the heater then element can be replaced , Just make sure you don't replace it with one thats is to high of a wattage .
trepka2001
it's popping the breaker for the water heater. it was working fine then one day it popped and hasn't worked since. happened at the end of the season so i haven't really put in a solid effort on my investigation but thought i would ask for the easiest solutions first before i go in and spend a whole lot of $$$ when it was only a bad wire or something.
kill the power and remove the cover on the heater and look for chafed wiring . if thats OK Its cheap and easy to replace the element just get the right size/ wattage . do not turn on the heater unless its full of water . and of course turn off the power when working on it
You can get the parts at RV shops and of all places ace hardware. :arrow:
LandVF36
Post by LandVF36 »
When my element went bad, it was tripping the breaker. They stocked the part at the local hardware store (check there first, the RV version is like a Marine version... same part, 2x the price and still the same part number).
Current Fleet:
2000 Carver 450 Voyager
1994 Scout 15'
2005 Caribe LCX9 dingy
1981 16' Hobicat
Oh and you can get temp control at Ace too :wink: :arrow:
randyp
Post by randyp »
Same problem with mine, too. Breaker tripping due to bad element. Replaced the element and all was good.
Randy P
1977 F-26 HT
"Blue Heron"
trepka2001
Thanks everyone!!!
