F241 cabin windows
SOBFROGG
F241 cabin windows
Post by SOBFROGG »
HELP!!!!!!
I am rather new to postinting here, but have been reading lots.
Hopefully someone can help. I am looking for the cabin windows for a 1976 F241. The old owner replaced them for one reason or another with Plexiglass. He never got it sealed up and the water came in :(.
Thanks for any help
Scott
Welcome aboard Scott. Try getting in touch with the folks at Beacon Marine, they run this forum and should be able to help you out. At the very least, they should be able to steer you in the right direction. I'm sure others with the same model will be along short with some input as well.
SOBFROGG
Post by SOBFROGG »
Thanks for the tip.
SOBFROGG
Post by SOBFROGG »
Bummer, no word from Beacon yet. The windows I am looking for are 16.5" x 3".
Atleast I have a little time while I am repairing all the water damage grrrrrrrrrrrrrr.
Scott, make a phone call. I hear they can take a while to respond to emails.
SOBFROGG
Post by SOBFROGG »
Well with no windows available besides 1 off custom ones, it looks like I will be removing the windows all together and glassing the hole closed. No more water probs :)
They never let much light in anyhow. I had to use cabin lights to see durring the day.
larglo
Post by larglo »
Couldn't you remove the Plexiglas windows, take them to a glass company and have them custom cut you some?
Larry
Larry - 1980 F25 HT
"Lady G"
Mt. Juliet, TN
larglo wrote:Couldn't you remove the Plexiglas windows, take them to a glass company and have them custom cut you some?
Larry
Thats what I would do
risctaker
Post by risctaker »
This must have been a "thing" with these old boats. The PO replaced all the glass windows in the main salon with smoked plexi as well. Of course they don't open and they also leak. Why the &*@%^& would anyone do that??? :x
aka "Basket Case"
383 Chryslers 280 HP V-Drives
Lincoln Harbor Yacht club
Weehawken, NJ
Lawman
Post by Lawman »
That is the cheapest way to go. I had 1/4 smoked lexan cut 1 1/2" beyond the window hole then screwed the new lexan on all around the edges with s/s srews and decorative washers, then used butyl tape as a gasket. No leaks and brand new windows!
1973 F30 Clean Machine
' Goomar '
(Italian for 'my mistress')
randyp
Post by randyp »
I agree that it may be a matter of replacing the gaskets around the windows. I'm not familiar with the F241, but my F26 front cabin windows leaked a lot until I removed the windows, frame and all and replaced with new smoked Lexan and redid the gaskets. No leaks in over 6 years now. If they're the side windows I added gutters over the tops of the frames (black vinyl self-adhesive extrusion that match the frames) and that really solved any leaking. All the cabin windows on my boat are plastic. The cockpit area windows are glass.
Randy P
1977 F-26 HT
"Blue Heron"
rvrrunner
Post by rvrrunner »
Dark plastic windows will heat up and expand and all sealants will leak after time . Tempered glass will not expand as much. Make a template and take to a glass shop and they will be able to make you windows you can add any amount of tint to them then.
randyp
Post by randyp »
Not if you know how to handle the expansion of plastics and which sealants to use. There are some really good posts on window replacments (plastic and glass) on this forum.
Randy P
1977 F-26 HT
"Blue Heron"
SOBFROGG
Post by SOBFROGG »
The windows I am having problems with have no frames. It looks like the originals fit into a recessed pocket. With the openings only being 16.5"x3" I am thinking they are no great loss.
Soooooooo, witht that in mind. I have thought about cutting the plexi I took off, cut it to size, and install it into the pocket. Orrrr, glassing them over.
Both options are doable to me. I have materials t cover up the holes and add some gelcoat. The plexi that the previous owner installed is 1.5" bigger than the opening all the way around. It was held in with 14 screws evenly spaced around the opening. By looking at all the sealent I pulled and scraped out along with all the rot I am fixing, this was not the way to fix the window.
I just do not want to be messing with this again for a while. I am lucky that the ramp I launch from is not due to open for another 2 weeks.
Thanks for all the sugestiongs and Ideas
Scott
