v-drives for 25 and 26 Trojans
myakka
Post by myakka »
Can anyone tell me what years had v-drives for these two models.
Mike
vabeach1234
Post by vabeach1234 »
I know the 1971-72 F26's had them. Not sure about the other years and F25's.
Ken
1972 Trojan F26 Express
1985 Dell Quay Dory 13
Hampton, VA
myakka
Post by myakka »
Thanks for the reply.
I'm investigating the possibility of installing a rebuilt deisel in one of these and figure the v-drive will allow me the lengthwise room for an inline 6. Height may still be a problem.
Mike
What aniline 6 diesel where you thinking about ? Height maybe more of a issue on the v-drive . I believe the F was V drive and the F was not . At least in the earlier ones . But I also have seen Many F25s being sold as F26s .
Don't take this as fact , just going by what I remember reading here.
myakka
Post by myakka »
I had not picked a specific engine yet, although I've seen some 4 cylinder fords(apx.65 hp) in a couple of Trojans and chriscrafts/allmands of that size with no height problems. They where used for small shallow water shrimping boats with top end of 7 kts. At 5kts, according to the re-builder, they would use 3/4 GPH. Nice fuel consumption but a little slow for me. I'm hoping for 16 to 18 kts and 4 to 6 GPH, but that is putting the cart ahead of the horse. Any engine recommendations would be great.
Mike
vabeach1234
My 72 F26 bearly has any room above the 318 that's in it. I know pretty much any Vortec Gm motor won't fit. I saw on Yachtworld a few years back that someone put in a perkins 50 hp 4.108 in a 72 F26 and it mounted right up to the paragon v-drive that was in it. Turned it into a trawler that went just hull speed. About 6-7 knots. I recall he burned 1/2 gph. As for newer diesels, I think the Cummins Mercruiser 2.8 may work. But like Paul said, I think the V-drive actually hinders engine choices due to height clearances in those models.
Ken
Hampton, VA
Heres a Diesel with a v drive V8 will sit lower then a inline
http://boatdiesel.com/Forums/index.cfm? ... d_ID=36101
foofer b
Post by foofer b »
1978 f26 was straight drive.
MY CURRENT FLEET
2003 KEY WEST 2020 WA
1978 14' ASHCRAFT SKIFF
nickbezy
Post by nickbezy »
My 1986 F26 is V-drive
myakka
Post by myakka »
Nickbezy
I hope you don't mind a couple of questions. I'm looking for dimensions.
1) height from the inside of the hull(hopefully not over the hollow keel) to the CL of the input shaft on the v-drive.
2) height from the CL of the input shaft on the v-drive to the underside of the cockpit deck. I know this wont be strait line measuring, a good estimate would be fine.
3) what model v-drive was installed.
And , if possible, a picture of the engine as it sits in the boat.
Mike
myakka
Post by myakka »
looks like this project has been done before.http://www.boatdiscover.com/detalji.php ... _objekta=1
Thats a Cummins 6BTA 330 (315 HP ) thats a tall engine they must have raised the deck , the paragon or Velvet dive Vidrive that came in that boat would not stand up to the cummins a ZF 220V would be a good choice .
