boom!! was the noise
sluggo
Post by sluggo »
I should know better than to stick my head in the engine compartment, but i did. You see the genny won't start, so I put a little 'dry' gas down the carb, started, and ran until the 'dry' gas(fleet?) went out . any way I went to try it again,(I am back in the back using the starter switch on the genny) and that's when it went boom!!! Scared the crap out of me!! this is what I saw
I think this is the muffler for the genny, as it has the output and then it exits over the side of the boat!!
Any thoughts, I think I found a replacement, and I think I can just swap things out. Probably won't put 'dry' gas in the carb again. (I think my problem is the choke adjustment)
I still don't know where the top of that thing is!! at least it is not in my eye!!!
(pic taken with iphone, best I had)
Sluggo
87 10 mid cabin
Ohio river
That was a water lift muffler .
When you winterize your boat next year use the non toxic antifreeze ( like you use for your water system ), that green stuff in you muffler is poison and illegal to pump over board .
_________________
sluggo
Ok but I use
Post by sluggo »
The low tox environmentally safe anti freeze. Tough to find sometimes and not cheap but it says a dog can drink it
But r you telling me the anti freeze caused the blow up
Sluggo
87 10 mid cabin
Ohio river
No not saying that , The non toxic stuff is cheap, use for RV . boat drinking water systems easy to find many auto parts stores and any RV place . Last time I got some pink stuff it was about 3 bucks a gallon
The muffler most likely blew from fumes from the dry gas .
That did not happen because of the antifreeze. Are you getting fuel to the carb? How much fuel is in the gas tank that feeds the genny? The genny's pick-up tube does not go all the way to the bottom of the tank as do the engines (safety, fuel for return trip). Usually a quarter tank or less will not feed the genny. Is this an Onan MCCK?
gettaway
Post by gettaway »
did the antifreeze come from the generator engine? (closed cooled)if so, you have much bigger problems
I've seen many mufflers explode from backfires...accumulated fumes in exhaust, flooded condition. Sometimes they go boom when after you've cranked the engine, released and then engaged the starter again. Good thing you weren't hurt.
sluggo
Post by sluggo »
Stripermann2 wrote:I've seen many mufflers explode from backfires...accumulated fumes in exhaust, flooded condition. Sometimes they go boom when after you've cranked the engine, released and then engaged the starter again. Good thing you weren't hurt.
me too!!! but this describes the situation that happened. I had it running, it stalled out, and then I started to re crank, and then boom. any suggestions?
Sluggo
87 10 mid cabin
Ohio river
sluggo
Post by sluggo »
gettaway wrote:did the antifreeze come from the generator engine? (closed cooled)if so, you have much bigger problems
not sure what you mean, when I winterizied, I took the intake house into an antifreexe bucket, and let it run to it went out the exhaust (just like the water does) so it makes sense that there might still be some antifreese in the muffler (as the muffler is between the genny and the water exit). this is the first time I've tried to run it so , there would still be anti freeze in the lines, or am I missing something??
Sluggo
87 10 mid cabin
Ohio river
Since you didn't name the make and model but if it's a Kohler, replace the spark plugs.
gettaway
Post by gettaway »
deleted
gettaway
Post by gettaway »
was thinking your generator had a closed sooling system using anti freeze, and that the antifreeze in your lift muffler maybe had come from the engine, however, it sounds as this is not the case.
sluggo
Post by sluggo »
Big D wrote: Is this an Onan MCCK?
yes it is
Sluggo
87 10 mid cabin
Ohio river
sluggo
Post by sluggo »
yes it is
Sluggo
87 10 mid cabin
Ohio river
Let us know when you've determined if you're getting good fuel flow to the carb.
