Used, working Garmin 180 GPS wanted
gruhs
Post by gruhs »
If you have this model Garmin GPS you would like to sell. All I need is the unit itself, mine quit working.
Contact: gruhs2001@yahoo.com
1977 Trojan Tri-cabin
"Seaweed"
Home port East Chicago, In.
k9th
Post by k9th »
Gary -
I think I have one onboard SeaDog. I know I have two backup units that used to be primary units and not sure the exact model number till I look at it. I will check Friday when I get there and let you know.
Is the 180 the only one you will consider?
Tim
"SeaDog"
1979 36' Tri-Cabin
gruhs
Garmin 180 wanted
Post by gruhs »
The reason I prefered the 180 is because I can plug it right in. Other Garmin might do the same but I don't know which ones.
Thanks for checking,
Gary
"Seaweed"
k9th
Post by k9th »
Most of the smaller Garmin units use the same power and antenna connector. Do you have charting cartography to load onto it?
Tim
"SeaDog"
1979 36' Tri-Cabin
gruhs
reply you question
Post by gruhs »
The old one that I have has the lake michigan chip (or what ever it's called) that I hope will plug into what ever I end up getting... that's another reason to stay with the same model then everything just plugs in and were good to go.
"Seaweed"
For what it's worth, that old Garmin uses a g chart/micro g chart which you can't get anymore and there is no support for it. The connections and antenna system are completely different than what Garmin has had out for the past 10 years or more. Plus you can't download newer version of charts.
Look on CL or check with some boating forums for a clean used one or upgrade to another newer model if you can.
Good luck.
gruhs
garmin
Post by gruhs »
Whoa... that's gonna make things more complicated, thanks for the info.
Gary
"Seaweed"
I have a Garmin 180 with the local SW US chart.
I also have the manual
Send me a PM if you are interested.
gruhs
garmin wanted...
Post by gruhs »
Thanks for the info and offers to fix us up with a replacement GPS. We think we have a reasonable deal on a model 182C in progress. If all goes well it will be nice to have a color screen.
Thanks,
Gary
"Seaweed"
k9th
Post by k9th »
Glad you found something & hopefully it works out.
Tim
"SeaDog"
1979 36' Tri-Cabin
I really like the 182C ( I have 2 ) but it still is a discontued unit Why not get somthine new and up to date , just a chart for the 182 is 130 and up .
