Left hand or right hand engine?
bkwesq
Post by bkwesq »
How can you tell?
1976 Trojan F 25
http://my1976trojan.wordpress.com
Knot Guilty
I trust you're talking about engine rotation. If the engine runs, look at the direction the balancer on the front of the engine is spinning. This is the easiest way to determine rotation if engine runs. Having said that, and this is where it gets complicated, when discussing marine applications, engine rotation is determined by standing behind the engine and looking at the direction the flywheel spins. So in a standard rotation engine, the balancer at the front will spin clock wise (right hand -RH). When talking marine, this would be considered standard rotation (flywheel spins left - LH). A counter rotating engine would be the opposite of above. Clear as mud?! Do a search on engine rotation, touched on many times here. Hope that helps.
Post by larryeddington »
through much trepedation I agree with the previous, usually the starboard engine will be the reverse rotation. Advice look at the harmonic balencer and turn starter if it turns to the left or Counter Clockwise it is the reverse turning engine.
Usually Port is normal rotation and starboard is reverse.
But I know already you may get confused, I did and now I have it straight in my noggin, (I think)
willietrojan
Post by willietrojan »
The link below has a good illustration
http://www.boatpartsinfo.com/2010/05/wh ... explained/
Spanish Fort, Al
Looking for 33 International
See I told you it would be confusing. Simplification is to heck with marine, look at the harmonic balancer (front of crankshaft which is at the water pump end of engine or front to car people). Clockwise or to the right is normal, counter clockwise or to the left is reverse.
Now you can think all you want about marine standard at flywheel end and it is correct but most of us can simply understand as above and determine what engine we have. Autos have standard rotation of harmonic balancer (crankshaft) turns to right or clockwise, so does my tractor, etc.
Important to note also that the position of the standard and counter rotating engines can change based on applications that include v-drives and certain reduction gears who's outputs are opposite to engine rotation. For example, in a typical standard propeller rotation configuration (strb = RH, port = LH) with straight shaft out, usually the counter rotator is on strb side. However, if a Warner 1.91:1 reduction gear is used, the engine would be placed on the port side. The mud is getting thicker!
And if you look at my f28 with paragon transmission reverse engine is on stbd and normal on port, which is convential though not always for all installations.
Repeat if you want know just look at the crankshaft front as you would in a car, you will not be confused once you observe rotation there.
Maybe!
bkwesq
Post by bkwesq »
I went to law school and have no idea what the hell you Two just said :) but thanks!
1976 Trojan F 25
Knot Guilty
vabeach1234
Post by vabeach1234 »
This site should explain it...
http://www.ebasicpower.com/faq/rotate.htm
Ken
1972 Trojan F26 Express
1985 Dell Quay Dory 13
Hampton, VA
Vabeach quoted website is the best I have seen an accurate.
bkwesq
Post by bkwesq »
Larry - my head sparkles - I used a bleach solution and a power washer a gross 30 minutes of my life but well worth the extra shower I had to take!
1976 Trojan F 25
Knot Guilty
BK, that is my plan also, you are moving much faster than me. These 100+ days have wore me down and a bout with my back which seems to be relenting now, both has slowed me down. I have two new engines to go in sitting fully assembled in my shop. I did the mechanics first now comes the mucking.
BTW did the bleach treatment work pretty good in salon etc?
here is one both are not sitting side by side ready to crank in the shop.
bkwesq
Post by bkwesq »
Wow looks nice and ready to be shipped to NJ! Yes the salon came up great - I ordered prescion cut diamonded plated stainless to cover all the white in the head and salon. It will look great and will be easy to clean.
1976 Trojan F 25
Knot Guilty
Look forward to a pic of the diamond plate. Does the waste system work as it should?
bkwesq
Post by bkwesq »
Well I'm not sure - I don't see a holding tank is it supposed to have one?
1976 Trojan F 25
Knot Guilty
