Trojan ??
Trojan ??
koviak
Post by koviak »
Looks like they streched an 11 meter to accomadate the diesels. I think it would be hard to do 40 knt. as they claim.
Dennis
1989 10 Meter Mid-Cabin
DOUGNASH
Post by DOUGNASH »
OK lets talk about this one.
I might be wrong but this thing is a total custom boat.
Somebody put some big money into this vessel.
I think it started out as a 10 meter.
It looks like they put the motors in the lower cockpit.
Arneson surface drives!!!! that is crazy, major investment here. I found an old quote from 10 years ago to convert my inboards to surfaces drives, it was like a 60k investment, they wanted around 15k for EACH 5 blade prop!
did they extend the length of the boat?
Its really hard to tell what is going on from the pics..
gettaway
Post by gettaway »
300 hp ford sabres driving surface drives?
hmmmm :shock:
too bad there are no more photos.
This is definately a stretched 10 meter, ot an 11.
Wonder hoe (exactly) they extended her?
Sectioned?
Still, not enough photos to be sure.
28 knots at 1200 rpm ? on plane at 1000 ? big lie or broken tachs LOL
DOUGNASH
Post by DOUGNASH »
can someone swing by the marina and take some more pics???
LoL
aaronbocknek
Post by aaronbocknek »
g'day! toss back a VB and enjoy the surf! then watch a game of footy.
okay, now that that's over with.... i like how they did the hard top. mike kulp, there is your design.
aaronbocknek@gmail.com
Post by larryeddington »
Something is amiss, states single diesel obviously two engines (diesel/gas?)
Mike Kulp
Post by Mike Kulp »
I do like the hard top, seems like a lot of work was put into this boat but I doubt the top speed.
Mike 1986 10 Meter mid cabin
Clearly no one here on the Forum noticed the MR. FUSION adapter on top of the engines.
Once you get the 1.21 gigawatts from the Mr. Fusion, everything will fall into place.
Just not too sure about the prop pitch...
larryeddington wrote:Something is amiss, states single diesel obviously two engines (diesel/gas?)
Diesel for sure . Twin Ford Sabre diesels that are turbo and after-cooled
RWS wrote:Clearly no one here on the Forum noticed the MR. FUSION adapter on top of the engines.
Actually I did notice that. But, I swear it's a thermo equalizer, coupled with a zeon cathode propelled by inert gasses compressed by the exhaust turbine, otherwise commonly known as a turbo. However, the waste gate linkage is probably loose at the knibbly pin...thus lowering the whole thrust factor to a minus 44. In which case, the boat will never do 28 knots at 1200 rpm! :roll:
