another Trojan Project boat
check out this one, the engines may be worth the price
http://sandiego.craigslist.org/csd/boa/2778511803.html
Like Ross said if the engines are ok they are well worth it and more But it gets better !! They are the 370B diamonds (Cpl2208 ) 370 metric HP 355 hp US Sweet engines . If that Boat was closer I would make a offer ( after a engine inspection ) the one trans/ vdrive is worth 3k it self (ZF220V ) good gear
- aaronbocknek
hey paul, i'll take a month off from flying and we can get a bunch of guys from here and bring to to virginia. could be fun!!prowlersfish wrote:Like Ross said if the engines are ok they are well worth it and more But it gets better !! They are the 370B diamonds (Cpl2208 ) 370 metric HP 355 hp US Sweet engines . If that Boat was closer I would make a offer ( after a engine inspection ) the one trans/ vdrive is worth 3k it self (ZF220V ) good gear
aaron
Where did you see that? Or are you basing that on the P7100 pumps and Sea Water cooled Intercooler?prowlersfish wrote:Like Ross said if the engines are ok they are well worth it and more But it gets better !! They are the 370B diamonds (Cpl2208 ) 370 metric HP 355 hp US Sweet engines . If that Boat was closer I would make a offer ( after a engine inspection ) the one trans/ vdrive is worth 3k it self (ZF220V ) good gear
If it was closer, Larry (PlanSea) would be getting diesels in his F36!
All Cummins B from the 300b to the 370 use salt water after coolers The Bosch inline pump (P7100 ) is used on the later 300 /315/330/370 Enginesrossjo wrote:Where did you see that? Or are you basing that on the P7100 pumps and Sea Water cooled Intercooler?prowlersfish wrote:Like Ross said if the engines are ok they are well worth it and more But it gets better !! They are the 370B diamonds (Cpl2208 ) 370 metric HP 355 hp US Sweet engines . If that Boat was closer I would make a offer ( after a engine inspection ) the one trans/ vdrive is worth 3k it self (ZF220V ) good gear
The early 300B us a inline denso pump ( as did some 430-450 C engines)
lower HP engines mostly ( not always)used The rotary pump .
Now How did I know what HP ? well the are diamonds so that makes them 330 or 370 then I looked at the photos and saw the cpl plate . from there it was easy .
You lost me ... Where do you see that they are the Diamonds? You can read CPL 2208 in the photo above?prowlersfish wrote: Now How did I know what HP ? well the are diamonds so that makes them 330 or 370 then I looked at the photos and saw the cpl plate . from there it was easy .
rossjo wrote:You lost me ... Where do you see that they are the Diamonds? You can read CPL 2208 in the photo above?prowlersfish wrote: Now How did I know what HP ? well the are diamonds so that makes them 330 or 370 then I looked at the photos and saw the cpl plate . from there it was easy .
Look at the other Photos , you can read the ID and CPL numbers
Someone flagged the ad but here are the photos
Diamond series
http://s776.photobucket.com/albums/yy47 ... CF4148.jpg
CPL 2208 370 metric hp (355 us)
http://s776.photobucket.com/albums/yy47 ... CF4718.jpg
Diamond series
I'd leave the boat and bring the engines homeaaronbocknek wrote:hey paul, i'll take a month off from flying and we can get a bunch of guys from here and bring to to virginia. could be fun!!prowlersfish wrote:Like Ross said if the engines are ok they are well worth it and more But it gets better !! They are the 370B diamonds (Cpl2208 ) 370 metric HP 355 hp US Sweet engines . If that Boat was closer I would make a offer ( after a engine inspection ) the one trans/ vdrive is worth 3k it self (ZF220V ) good gear![]()
aaron
Roger.
I hadn't looked at the Photobucket pictures. Nice!
If these engines haven't been under water ....
Looks like one of the V-Drives has been taken ...
But the head and the Genny really look like they went under:
Can you imaging 740HP in an F32? Dangerous!
