adding fuel at sea question
Any long range cruisers out there?? I measured my sole internal gas tank yesterday and per dimensions its capacity is 77 gallons. This will be ok for most days offshore but I was thinking about mounting an external gas holding tank somewhere up on fore deck. Then have a pump, hose and nozzle to add to the main tank through the gas fill on side of boat when needed/emergency. I have a brand new 20 gallon or better aluminum tank in my barn a friend gave me. Anyone with any similar setup, ideas or precautions dealing with fueling at sea?
+1
What kind of boat do you have? I would think you should be able to fit a 20gal tank somewhere (marine grade) and plumb it into the main with an approved shutoff valve.
Other things to concider : What will the Coast Gaurd think of it? What will it look like, tank and hoses sitting on your bow?
Ron
Ron
Ronald Reagan
1987 F36 Tri-Cabin
Twin 270 Crusaders
"Special K"
Upper Bay, Chesapeake Bay
Ronald Reagan
1987 F36 Tri-Cabin
Twin 270 Crusaders
"Special K"
I agree with the plumbed-in tank. If you have to put it someplace out-of-the-way that makes it impossible to simply valve in-and-out of the supply circuit, you can always purchase a small fuel transfer pump to transfer the fuel back into one of the main tanks. The company I work for makes such pumps.
Tim
"SeaDog"
1979 36' Tri-Cabin
"SeaDog"
1979 36' Tri-Cabin
installed tank...with a transfer pump, I've seen 12v gas pumps used..
options in case of space...agree if not needed don't put it in...but PUT the thought there to spark ideals on where the tank/tanks can go....you know food for thought....think out of the box.....
I'm not liking the idea of a tank topsides. How will you vent it so that there is no spillage in bad seas. The lower it sits below decks, the less the liquid will move around, and it still has to go up hill through the vent line before spilling if the vessel is rollong. I wouldn't like that much fuel baking in the sun. If metal tank, for safety, it has to be grounded. Also think you stand a better chance of venting fumes into the boat this way, even with the slightest breeze in the right direction. Strongly advise against it. Find a way to get one down below where it belongs. There are a ton of options out there for tanks.
fueling at sea
Wow, thanks for the responses. You guys changed my mind on the top side tank. I think I can get this spare tank I have below deck in one area. No room to change out tank that is in there for a bigger tank. That was already done and that area is practically maxed out. I had pondered the venting issue and how to make it look good. Could not come up with a great idea so decided to ask you experts, thanks again..
