Changing hatches ???
My F-32'er owner asked me today if it is any solution to replace all 3 hatches in to newer ones.
Detlef likes more cleaner and deeper hatches as originally installed.
Greetings - Heiner
Greetings - Heiner
- vabeach1234
I'm not familiar with the F32 hatches but I found this on Craigslist on the eastern shore of Virginia.
http://easternshore.craigslist.org/boa/3003515766.html
May be worth a look.
Ken
1972 Trojan F26 Express
1985 Dell Quay Dory 13
Hampton, VA
Hampton, VA
Heiner, what's wrong with yiur original hatches? When propeely cared for they work well and look good.
Hi Jamie, it's all very well with the hatches. Detlef only asked me if there are less high and edged hatches.
He knows only the newer yachts and their hatches he like very much.
It is his boat and I'm just the skipper. Maybe even someone from the forum can post a picture of rebuilt hatches?
Does somebody knows the dimensions of the neckline ?
Greetings - Heiner
Greetings - Heiner
- vabeach1234
The craigslist ad is very vague. I'd get pictures and a little more info before I'd offer him $1.EM63 wrote:Thank's guys, I've made him an offer about 2000.00 US$ inc. shipping.
Also asked for some pictures.
Greetings - Heiner
Ken
Hampton, VA
Hampton, VA
try this site out...
http://greatlakesskipper.com/category-1 ... tches.html
installed them on my boat and they look great.
- ready123
I believe he means that the deck rises to another level (ledge) around the hatch. On my F32 the deck remains flat till it meets the side of the Teak hatch base.EM63 wrote:I emailed him and got this answer:... what does he mean ? Were there anytime any differences ?is the deck raised around the wood hatch?
Greetings - Heiner
My buddy put in low profile modern hatches and he had to cut a larger hole in one direction I believe to make them fit.
The middle boat in this picture.
Another view... note the home made hardtop
Hi Michael - very nice pictures THANK YOU very much.
May be your buddy has some more detailed pictures from above and inside ??
As far as I know: In fact there are no actually well fitting hatches at the market, to use the original necklines ?!?
Every stuff e.g. Bomar has to be custom made ?
Otherwise, David's work is also very impressive:
Greetings - Heiner
--DAVIDLOFLAND wrote:
Greetings - Heiner
- ready123
Sorry no more detailed pictures. IMO the easiest way to go if replacing the hatches is to select a current model and cut the deck to suit. It is quite easy as you don't have to deal with deck finish as much since you are making the hole larger.... just reinforce the new cut edge with solid wood and the new hatch flange will cover the changed edge topside.EM63 wrote:Hi Michael - very nice pictures THANK YOU very much.
May be your buddy has some more detailed pictures from above and inside ??![]()
I bought Michael's 3 hatches from his F32 a few years ago, as spares. Wood framed from the git-go...(Original)
And the ones on my boat are also wood framed. The seller obviously doesn't know what he's talking about. Run Forest, run!
