city water inlet
city water inlet
when my boat was taken apart earier this year (by an employee, fired him for it) the connection for the city water was removed, kids are not impressed. The reasoning was he figured the inlet through the floor at the back was a poor idea, and I should buy a new fitting with a 90 on it to allow to cut a hole through the back of the boat so the hose does not go over the sides.
thoughts?
thoughts?
Dave, Mine goes thru the stern just above the swim platform and the hose is out of the way . I like there...
I have never used my shore water hook up. When we go to a marina for a long week-end, I use the boat potable tank and fill as needed.
-1995 350 express
with big blues (454 Crusaders)
-2011 Caroling Skiff J-14 (Tohatsu 30hp four stroke)
-1996 Sea Ray SeaRayder jet (Merc 90hp)
-1990 BeachCat 20. Fiberglass pontoon (2013 Merc 60hp big foot)
My tri-cabin has the shore water inlet on top of the aft deck very close to the port side fuel fill inlet and right next to the water inlet for the fresh water tanks. I wish it were down where Tony described. My hose has to run on the back walking surface or hang over the stern which I don't like. I have thought about moving it but decided the amount of work was not justified so I just tolerate it.
Tim
"SeaDog"
1979 36' Tri-Cabin
"SeaDog"
1979 36' Tri-Cabin
I don't use mine much, read to many a good boat has gone down due to failures in piping..kevinz wrote:I have never used my shore water hook up. When we go to a marina for a long week-end, I use the boat potable tank and fill as needed.
I use mine all the time, but turn the shore water off and relieve the pressure when we leave for the week. I prefer that to hearing the water pump run every time I open a faucet.alexander38 wrote:I don't use mine much, read to many a good boat has gone down due to failures in piping..kevinz wrote:I have never used my shore water hook up. When we go to a marina for a long week-end, I use the boat potable tank and fill as needed.
Tim
"SeaDog"
1979 36' Tri-Cabin
"SeaDog"
1979 36' Tri-Cabin
- ready123
+1k9th wrote:I use mine all the time, but turn the shore water off and relieve the pressure when we leave for the week. I prefer that to hearing the water pump run every time I open a faucet.alexander38 wrote:I don't use mine much, read to many a good boat has gone down due to failures in piping..kevinz wrote:I have never used my shore water hook up. When we go to a marina for a long week-end, I use the boat potable tank and fill as needed.
I do not even know if my pump works, when I turn my taps on nothing happens... I do use city water but if you look on your city intake there is a regulater thats bring the pressure down to around 15-18 psi so as not to blow a line (city is 50-60 psi) and as long as you turn it off when you are not at the club and have a high water alarm it is a non issuekevinz wrote:I have never used my shore water hook up. When we go to a marina for a long week-end, I use the boat potable tank and fill as needed.
- aaronbocknek
the PO reconfigured my city water inlet and is now next to the transom light. i have not one, but two regulators dockside. one at the faucet, the other connected to the city water inlet, which is connected to a Y connector that can turn on and off. when i leave the boat, i turn off the Y connector, and depressurize the hose with the other lever. i then leave the forward head faucet turned on, so that if someone turns on the city water dock side and opens the tap at the Y connector, the water flows right out the thru hull in the forward head. otherwise, the water is stopped at the shore hookup Y connector. i know, too many items, but, i like the peace of mind with redundant systems.
Our marina rules state you cannot leave the water line connected to the boat when not at the Marina. I disconnect the hose when we leave for the week.aaronbocknek wrote:the PO reconfigured my city water inlet and is now next to the transom light. i have not one, but two regulators dockside. one at the faucet, the other connected to the city water inlet, which is connected to a Y connector that can turn on and off. when i leave the boat, i turn off the Y connector, and depressurize the hose with the other lever. i then leave the forward head faucet turned on, so that if someone turns on the city water dock side and opens the tap at the Y connector, the water flows right out the thru hull in the forward head. otherwise, the water is stopped at the shore hookup Y connector. i know, too many items, but, i like the peace of mind with redundant systems.
Aaron
____________________________
1975 36' Tri Cabin
"Keep it up!"
E-Mail : aweimer@comcast.net
Lake Erie, OH
1975 36' Tri Cabin
"Keep it up!"
Lake Erie, OH
Same here - that's why I asked. I was advised early in life not to use this.alexander38 wrote:I don't use mine much, read to many a good boat has gone down due to failures in piping..kevinz wrote:I have never used my shore water hook up. When we go to a marina for a long week-end, I use the boat potable tank and fill as needed.
