Trans fluid change
jddens
Trans fluid change
Post by jddens »
I'm getting ready to do my annual fluid changes. Normally I just change engine oil but want to include the transmissions this year. I have hurth direct drives. I'm assuming I can just pump out the fluid through the dip stick hole and refill with dextron?
Is this assumption correct?
Any idea of capacity?
Do I check level warm or cold?
Any tips are greatly appreciated!
Thanks in advance..........John
1998 Kawasaki ZXi 1100
What model hurth Gear ? some take engine oil . many have a drain plug but in most cases it can be suck out ( you may not get it all )
jddens
Post by jddens »
Not sure of the model, I'll check tomorrow......thanks.......John
jddens
Post by jddens »
They appear to Have dextron in them......red color on dipstick.....if theres a drain there's no way to get under it. I'll pump it out and refill using dip stick mark, idle and shift for awhile and recheck........sound like a plan?". thanks.....John
sounds like a plan
