odd engine start question
jefflaw35
Post by jefflaw35 »
V8 chevy 327 or 350, shouldn't matter either way. Turn key and while its cranking up to ignite the fuel it starts heavy smoking out of the valve cover oil fill vent. All this in an instant of starting up a sup'ed up motor. Oil level is good, tranny is low, slips a little we aready know. Engine cold. How do you get smoke from the valves while cranking a motor at start up? seems like a serious problem to me.. Any input guys?
Blow-by....Oil getting past rings, unvented crankcase...could be a host of things. What year? Let us know when you have more info. Is this out if a car?
Stripermann2 wrote:Blow-by....Oil getting past rings, unvented crankcase...could be a host of things. What year? Let us know when you have more info. Is this out if a car?
Agreed
Allen Sr
Post by Allen Sr »
Valve seats worn bad/not seating properly?
2011 Trojan Rendevous
Solomons Get Together 2011
Ocean City 2012,2013,2015
jefflaw35
Post by jefflaw35 »
thanks guys, they all sound like good possible ideas. I was just worried when it started happening becuase its not mine, Claims its an early 80's 350. Im not sure if its possible to tell. Yea its in this 1933 ford model B I have here. moving it around in short spurts alot and this just started happening. Guess its nothing to worry about on my part. thanks for helping....
jefflaw35
Post by jefflaw35 »
after a few chats today I am starting to think Allen Sr is right. Long sits and short runs, Valve is probly stuck. Im going to drive it around the hood soon as I can for an hour or so... Owner says no worries... thanks again
Jerry
Post by Jerry »
Do a cylinder leak down test and you will know for sure if that is the problem.
