1976 Trojan 26.6'
Chitimacha
1976 Trojan 26.6'
Post by Chitimacha »
I am looking at the purchase of a 1976 26.6; dont have the hull number yet does anyone have any info on this boat also it has a crack head what would be the estimate to fix this problem
Thanks in advance
Welcome .
Most likely a F the hull ID numbers will tell the story . . Cost of replacing a head ? the will vary on what engine you have and other factors , other damaged parts rusty bolts etc . and of course the labor rate in your area .
why do you think it has a cracked head ?
Allen Sr
Post by Allen Sr »
Welcome to the forum. More info would be nice. Hull id no., engine make/size,the more info the better we can answer your questions.
2011 Trojan Rendevous
Solomons Get Together 2011
Ocean City 2012,2013,2015
k9th
Post by k9th »
Welcome aboard!
Tim
"SeaDog"
1979 36' Tri-Cabin
jddens
Post by jddens »
Welcome.....odds are if you have a cracked head and want to replace it you probably should consider a total rebuild.........John
1998 Kawasaki ZXi 1100
Vitaliy
Post by Vitaliy »
thats assuming that we are talking about the engine that is...
1974 F36 Tri-Cabin "Jorallyn"
aaronbocknek
Post by aaronbocknek »
Vitaliy wrote:thats assuming that we are talking about the engine that is...
i caught that too vitaliy. :shock:
aaronbocknek@gmail.com
Chitimacha
1976 Trojan 26.4'
I have the info now can you tell me where I can find info on this boat
1976 Trojan 26.4'
Boat # MD8832-2
Hull # TRJ062080176
Model # 261-6210
You have a 1976 F26 10.5' beam approx dry weigh of 5450 lbs 27" draft .
the most common engine was the Chrysler 318 but there were other options ( mercruser )and being 35 years old may have been repowerd , If for some reason your having troulde ID ing the engine a photo would help
Most the info you need is available here so ask away . Of course when asking refer to it being a 76 F26. A owners manual is available thru Beacon marine .
