timing marks
midman45
timing marks
Post by midman45 »
where are the timing marks on the 318 i can see it on the crank but i don't see the pointer any help would be great
f26 on georgian bay
Re: timing marks
Some marine 318s have timing marks on the flywheel / bell-housing
Re: timing marks
Post by larryeddington »
two places one is through the bell housing under a rubber flap right below the distributor area the other is on the front of the engine at base of timing cover you will find a pointer, same as on autos. PF has seen many more of these and he would know that some do not come with the front one. I purchased two rebuilt 318s and they did not have the front ones, it was my opinion that the assemble just left them off as the rear one is adequate, the rubber covering flap was gone also. The flywheel is marked so you can time either a reverse or normal engine.
