1987 Trojan International windshield washers wont turn off
woman to blame
Post by woman to blame »
After the winter ( I heat the bilge and the cabin) when I turn my fresh water pump on my windshield washers spray continuously (Ive tried the switches to no avail) They worked previously. Any Ideas? Thanks so much for any direction :)
Re: 1987 Trojan International windshield washers wont turn o
Welcome aboard. The International crew can probably chime in with more info but today's generation units use solenoid valves to allow the water to go through. I suspect your valve has a ruptured diaphram or a plunger that is stuck open. Age plays a part here but a lot of these fail due to improper winterizing if you're in an area where winterizing is a requirement.
BobCT
Post by BobCT »
Yes, had the same problem. Do yourself a favor and install a shutoff valve in the line going up to the washers. Remove the trash can in the galley and you'll see the line. As you now know, there's no way to stop it short of turning off the pump.
The problem is the solenoid which is located behind the helm. It'll be on the Stb side kind of up high. If your throttle controls were removed you would see it. Not saying to remove those but a point of reference. My VHF is mounted just below and when I remove that I'm looking right at it. It's brass/black and you'll see the clear washer lines going in/out.
I took mine apart and cleaned/lubed the little piston and it's worked fine ever since. Did you remember to winterize the washer lines by spaying the nozzles? If not, the solenoid might be broken from the cold. The shut off valve is easily had at Lowes, I'm sure I posted the part number here before. Just cut the hard line and pop on, 5 min job.
woman to blame
Bob your awesome, thx so much
tcollins2
Re: 1987 Trojan International windshield washers wont turn off
Post by tcollins2 »
I have the 12M Express and I found my solenoid in the arch on the starboard side. Does anyone have a part number for this? I don't think it was winterized one year, it leaks after the solenoid.
The tubing goes up thru the windshield frame and is cut off at the stbd wiper. The sprayers were removed and were closed up with silicone. Anyone have a link to new ones? Is there a T fitting I need too to get the water to flow to the port windshield?
Thanks.
Flyboy
Post by Flyboy »
I have a 1981 10 Meter International. The supply for my washers starts on the Starboard side of the boat and runs behind the medicine cabinet in the Head. I have an access panel in the ceiling at the base of the stairs to access the lines for the horns and the washer line can also be seen there. The solenoid is behind the helm, I have a large access panel on the starboard side of the boat between the helm and the hull. I do not think it is factory, but may be.
keep in mind the hardware locations will be different between mid cabin models and the express, as well as sedans, flybridges and the larger models too.
Try Beacon marine
