ANTIFREEZE
MUSICMAN7775
ANTIFREEZE
Post by MUSICMAN7775 »
HOW MANY GAL. OF ANTIFREEZE DO I NEED TO RUN THROUGH MY CHRYSLER 360'S TO DO IT PROPERLY?
The Dog House
Re: ANTIFREEZE
Post by The Dog House »
MUSICMAN7775 wrote:HOW MANY GAL. OF ANTIFREEZE DO I NEED TO RUN THROUGH MY CHRYSLER 360'S TO DO IT PROPERLY?
The commonly accepted amount is 5 gallons, but I put through 10 gallons because antifreeze is cheap and engines are expensive. :mrgreen:
Former boat: 1971 Trojan F26
Re: ANTIFREEZE
I pay my marina to do it (both engines, genny, and A/C), because if it's not done right , any repairs are on their dime.
MUSICMAN7775
Re: ANTIFREEZE
Always had the F-26 done by the marina but thought I could save money doing the twins in the F-32.
I think the fact that it their issue if something goes wrong sound right,
Good plan.
Thanks , Don
Bob Giaier
Re: ANTIFREEZE
Post by Bob Giaier »
I have 400 Chryslers. I just winterized them on Sunday. A few years ago I added tee fitting with a plug just after my thru hull fitting. I attach a funnel and pour antifreeze while the engine is running at temperature. My boat draws raw water thru the engine (no heat exchangers). The engine needs to be warm (thermostat open) otherwise the antifreeze doesn't go thru the engine.
Re: ANTIFREEZE
Bob Giaier wrote:The engine needs to be warm (thermostat open) otherwise the antifreeze doesn't go thru the engine.
I know this is the conventional thinking but you don't need to do that IMO. I've done thousands without a warm up as I've always done them out of the water for several reasons and have always had the block fill with antifreeze. If you need peace of mind, pull a plug just long enough to check, you should be doing that anyway.
lawyerdave71
Re: ANTIFREEZE
Post by lawyerdave71 »
captainmaniac wrote:I pay my marina to do it (both engines, genny, and A/C), because if it's not done right , any repairs are on their dime.
DITTO
Captain Dave -
1978 F30 Flybridge Express
Re: ANTIFREEZE
I agree
Bob Giaier
Re: ANTIFREEZE
I have trouble agreeing to that. I like to play it safe knowing that when the thermostats closed water mostly recirculates and doesn't go thru the block. There are 2 impellers on my pump. One for the engine block and one for the exhaust. With the thermostat closed the water recirculates and also goes directly thru the exhaust.
Like I said, I just like to play it safe and do it hot.
Re: ANTIFREEZE
Bob, like I said, I've done thousands with single and dual pocket pumps and have a zero failure rate without warming up the engines. But you need to do it the way you feel comfortable for sure. Me, no worries doing it cold, I know some always by-passes the t-stat and a quick check confirms it. When you do as many boats as I do, you quickly learn that doing it while the boat is still in the water can be a pain sometimes so I haven't done it that way for years. As a result, I can't warm them up first, not efficiently anyway.
