Hydrolic steering reservoir filling tip
I am putting the auto pilot from my old F32 with mechanical steering on my 10 meter with hydrolic steering. After I had the new hoses made and installed with the new hydrolic pump that replaced the mechanical ram, I needed to refil the hydrolic reservoir. There is a large plug on top that the air valve screws into. I could not get it to budge and having outgrown the grab a big buddy and six foot cheater bar mentality because that usually resulted in breakage and wrecked parts, I resorted to straining my thought process on how to fill the reservoir through the 1/4 inch hole the valve screwed into with out making a mess. The valve unscrewed with no hassle. Small funnel or baster tube is what I came up with. Off to Wally world to see what was available. Even their smallest funnel would not fit into the hole and when I was looking at the basting tubes, they were also too big. And then I saw it hanging on the rack. A turkey marinade injector. A large hypodermic needle. $5.00 later and back to the boat. Clipped off all but about 1/4 inch of the needle and proceeded to fill the reservoir in short order and with out making a mess. That needle is now part of the boat tool collection. Hope this helps some one.
Gary
Miss Vicki
10 meter international express
F32 express
S. Haven, Mi.
Miss Vicki
F32 express
S. Haven, Mi.
Re: Hydrolic steering reservoir filling tip
Glad you got it done , hopefully that will help someone else
CaptG, Way to go on the restraint of avoiding the cheater Bar!!! Thank goodness we get smarter as we get older!
Good tip, thanks for sharing!
Todd Pote
1987 10 Meter Mid Cabin
Double Pote-N_Sea
Double Pote-N_Sea
